  4. Chain and sprockets
Chain and sprockets
6 Posts 3 Posters 1.4k Views
  • rking7888R Offline
    rking7888R Offline
    rking7888
    Hi guys, looking to buyba chain & sprocket kits for my 95 dt with a 88 3dp engine, all the kits say different years (90-03, 88-95 etc) all contradict each other, is it just a tooth difference? Can anyone advise please, also I'm running 98 wheels. Thanks guys any help will be appreciated
    CalumC S 2 Replies Last reply
    • rking7888R rking7888
      @rking7888 I would have thought it'll just be the tooth difference. The output shafts are the same from 88-07. The engine only went through minor revisions, so any sprocket from any year should fit.
        @rking7888
        Make sure you get the rear sprocket with six bolts...
        There is a gold o-ring chain and JT sproket set on fleabay for about £45. I’ve had 4000 trouble free miles from it. Just adjusted it every 1000 mile or so...
        Just search for JT oring chain dtr125
        rking7888R 1 Reply Last reply
          @rking7888
          rking7888R Offline
          rking7888R Offline
          rking7888
          @spookdog
          Thanks for your help mate, that's the kit I was looking at, seemed well cheap, I swear I payed like 70 quid for my cr chain. I wasn't aware there was a bolt Change on the rear wheel I thought the hubs never changed?
            @spookdog
            rking7888R Offline
            rking7888R Offline
            rking7888
            @rking7888
            Also wasn't sure between the o ring set or the std d.i.d set
              @rking7888
              @rking7888
              I just saw loads of ’dtr’ sprockets Being sold with 4 bolt holes, they looked like dtlc or yz
              Go with O-rings please! X section if they do them. They are both better
