  4. Swing arm movement
Swing arm movement
17 Posts 5 Posters 3.1k Views
    @kylescave Should still be able to get these parts from Yamaha
    90387-164U8 - Part number for the collars
    I'd grab genuine collars then get the bearings from SimplyBearings.co.uk
    K
    K
    kylescave
    @Calum Okay sounds good, any chance you know the bearing size or can direct me to where i can find them? Many thanks.
    • K kylescave
      @kylescave The bearings will have markings on them that you can use for reference. Simplybearings.co.uk will have them, that's where I got them from.
      https://www.ebay.co.uk/itm/112551533577
      But someone is selling them on eBay for £20
      K 1 Reply Last reply
        K
        K
        kylescave
        @Calum Aren't those the swing arm bearings though? They are the ones I've replaced. Or is it possible that the linkage uses the same bearing.
        • K kylescave
          @kylescave No sorry, they were the swinging arm bearings.
          I vaguely remember doing them on mine. But I can't recall what the sizes were. Just press them out and get the part number from them
            K
            K
            kylescave
            @Calum Alright no worries, I'll give that a go. Thanks for the advice.
            • K kylescave
              @kylescave
              Do a search for :
              ‘Yamaha DT125R rear suspension linkage repair kit’
              It’s not cheap (@ £110) but once done and properly maintained it should last forever. Nobody greases up the nipples on these! That’s why they fail...
                @spookdog that and by this point they are like a million years old
                • NottsbikerN
                  NottsbikerN
                  I've collected all the parts to do the swingarm on my TDR (basically a DTR) from Yamaha / Wemoto and they were horrendously expensive. Bet its cost something daft like two hundred quid or even more for the 125 bits.
                  Strange then that All Balls make a kit for my DT200WR that includes everything across a couple of kits for around a hundred quid!
                  • NottsbikerN Nottsbiker
                    @Nottsbiker
                    Most stolen bike in the UK tax!...
                    If you checked the sizes I bet most bits are the same. The 200 does have an ally swing arm though, no?...
                      @Nottsbiker
                      NottsbikerN
                      NottsbikerN
                      @SpookDog yes the 200wr has an aluminum swingarm but so does my 125r (got a dt200r one) and I bet you are correct that loads of bits are the same.
                      Oddly though the the 200 is narrower than the 125 with the linkage mount a different distance from the pivot so would not be a direct swap either
