  4. Swing arm movement
Swing arm movement
17 Posts 5 Posters 3.0k Views
  • D DTR+NSR
    @kylescave there's a needle bearing and sleeve, where the swingarm pivots on the frame bolt. Pretty sure its a common size bearing, possibly 22x28x20mm but don't hold me to that.
    K
    K
    kylescave
    @DTR-NSR I've changed the sleeve bearing that the swing arm bolt goes through if that's what you mean. But i think the movement is coming from the rear shock linkage. where it bolts onto the swing arm? Or is that what you meant.
    I was going to replace the bearings/sleeve in that link however im struggling to find a kit.
    • K kylescave
      @kylescave Should still be able to get these parts from Yamaha
      90387-164U8 - Part number for the collars
      I'd grab genuine collars then get the bearings from SimplyBearings.co.uk
      K 1 Reply Last reply
        K
        K
        kylescave
        @Calum Okay sounds good, any chance you know the bearing size or can direct me to where i can find them? Many thanks.
        • K kylescave
          @kylescave The bearings will have markings on them that you can use for reference. Simplybearings.co.uk will have them, that's where I got them from.
          https://www.ebay.co.uk/itm/112551533577
          But someone is selling them on eBay for £20
            K
            K
            kylescave
            @Calum Aren't those the swing arm bearings though? They are the ones I've replaced. Or is it possible that the linkage uses the same bearing.
            • K kylescave
              @kylescave No sorry, they were the swinging arm bearings.
              I vaguely remember doing them on mine. But I can't recall what the sizes were. Just press them out and get the part number from them
                K
                K
                kylescave
                @Calum Alright no worries, I'll give that a go. Thanks for the advice.
                • K kylescave
                  @kylescave
                  Do a search for :
                  ‘Yamaha DT125R rear suspension linkage repair kit’
                  It’s not cheap (@ £110) but once done and properly maintained it should last forever. Nobody greases up the nipples on these! That’s why they fail...
                    @spookdog that and by this point they are like a million years old
                    • NottsbikerN
                      NottsbikerN
                      I've collected all the parts to do the swingarm on my TDR (basically a DTR) from Yamaha / Wemoto and they were horrendously expensive. Bet its cost something daft like two hundred quid or even more for the 125 bits.
                      Strange then that All Balls make a kit for my DT200WR that includes everything across a couple of kits for around a hundred quid!
                      • NottsbikerN Nottsbiker
                        @Nottsbiker
                        Most stolen bike in the UK tax!...
                        If you checked the sizes I bet most bits are the same. The 200 does have an ally swing arm though, no?...
                          @Nottsbiker
                          NottsbikerN
                          NottsbikerN
                          @SpookDog yes the 200wr has an aluminum swingarm but so does my 125r (got a dt200r one) and I bet you are correct that loads of bits are the same.
                          Oddly though the the 200 is narrower than the 125 with the linkage mount a different distance from the pivot so would not be a direct swap either
