Swing arm movement
So i have been building two DT 125r's for a while now. However they both seem to have up and down movement in the swing arm. I'm struggling to find a bearing kit that i'm certain would fit.
Any help or advice would be appreciated.
when on a stand the swing arm will move about 3-5 mm up and down. I'm sure this would fail an MOT so want to get it sorted ASAP so i can sell it.
You mean at the frame/swingarm bolt?! That sounds beyond wear. I’d check the bolt is the proper size...
@kylescave there's a needle bearing and sleeve, where the swingarm pivots on the frame bolt. Pretty sure its a common size bearing, possibly 22x28x20mm but don't hold me to that.
@SpookDog No i do not think it is the swingarm bolt. From what i can see its moving from the rear shock linkage. I'm not sure of the name. Wishbone? Dogbone? So i believe its the bearings or sleeves in that.
But both my Dt's have this issue otherwise i would have swapped the part for now.
@DTR-NSR I've changed the sleeve bearing that the swing arm bolt goes through if that's what you mean. But i think the movement is coming from the rear shock linkage. where it bolts onto the swing arm? Or is that what you meant.
I was going to replace the bearings/sleeve in that link however im struggling to find a kit.
@kylescave Should still be able to get these parts from Yamaha
90387-164U8 - Part number for the collars
I'd grab genuine collars then get the bearings from SimplyBearings.co.uk
@Calum Okay sounds good, any chance you know the bearing size or can direct me to where i can find them? Many thanks.
@kylescave The bearings will have markings on them that you can use for reference. Simplybearings.co.uk will have them, that's where I got them from.
https://www.ebay.co.uk/itm/112551533577
But someone is selling them on eBay for £20
@Calum Aren't those the swing arm bearings though? They are the ones I've replaced. Or is it possible that the linkage uses the same bearing.
@kylescave No sorry, they were the swinging arm bearings.
I vaguely remember doing them on mine. But I can't recall what the sizes were. Just press them out and get the part number from them
Do a search for :
‘Yamaha DT125R rear suspension linkage repair kit’It’s not cheap (@ £110) but once done and properly maintained it should last forever. Nobody greases up the nipples on these! That’s why they fail...
I've collected all the parts to do the swingarm on my TDR (basically a DTR) from Yamaha / Wemoto and they were horrendously expensive. Bet its cost something daft like two hundred quid or even more for the 125 bits.
Strange then that All Balls make a kit for my DT200WR that includes everything across a couple of kits for around a hundred quid!
Most stolen bike in the UK tax!...
If you checked the sizes I bet most bits are the same. The 200 does have an ally swing arm though, no?...
@SpookDog yes the 200wr has an aluminum swingarm but so does my 125r (got a dt200r one) and I bet you are correct that loads of bits are the same.
Oddly though the the 200 is narrower than the 125 with the linkage mount a different distance from the pivot so would not be a direct swap either
