  4. Swing arm movement
Swing arm movement
17 Posts 5 Posters 3.1k Views
    @kylescave
    You mean at the frame/swingarm bolt?! That sounds beyond wear. I’d check the bolt is the proper size...
    K
    K
    kylescave
    @SpookDog No i do not think it is the swingarm bolt. From what i can see its moving from the rear shock linkage. I'm not sure of the name. Wishbone? Dogbone? So i believe its the bearings or sleeves in that.
    But both my Dt's have this issue otherwise i would have swapped the part for now.
    • D DTR+NSR
      @kylescave there's a needle bearing and sleeve, where the swingarm pivots on the frame bolt. Pretty sure its a common size bearing, possibly 22x28x20mm but don't hold me to that.
      K
      K
      kylescave
      @DTR-NSR I've changed the sleeve bearing that the swing arm bolt goes through if that's what you mean. But i think the movement is coming from the rear shock linkage. where it bolts onto the swing arm? Or is that what you meant.
      I was going to replace the bearings/sleeve in that link however im struggling to find a kit.
      • K kylescave
        @kylescave Should still be able to get these parts from Yamaha
        90387-164U8 - Part number for the collars
        I'd grab genuine collars then get the bearings from SimplyBearings.co.uk
        K 1 Reply Last reply
          K
          K
          kylescave
          @Calum Okay sounds good, any chance you know the bearing size or can direct me to where i can find them? Many thanks.
          • K kylescave
            @kylescave The bearings will have markings on them that you can use for reference. Simplybearings.co.uk will have them, that's where I got them from.
            https://www.ebay.co.uk/itm/112551533577
            But someone is selling them on eBay for £20
              K
              K
              kylescave
              @Calum Aren't those the swing arm bearings though? They are the ones I've replaced. Or is it possible that the linkage uses the same bearing.
              • K kylescave
                @kylescave No sorry, they were the swinging arm bearings.
                I vaguely remember doing them on mine. But I can't recall what the sizes were. Just press them out and get the part number from them
                  K
                  K
                  kylescave
                  @Calum Alright no worries, I'll give that a go. Thanks for the advice.
                  • K kylescave
                    @kylescave
                    Do a search for :
                    ‘Yamaha DT125R rear suspension linkage repair kit’
                    It’s not cheap (@ £110) but once done and properly maintained it should last forever. Nobody greases up the nipples on these! That’s why they fail...
                      @spookdog that and by this point they are like a million years old
                      • NottsbikerN
                        NottsbikerN
                        I've collected all the parts to do the swingarm on my TDR (basically a DTR) from Yamaha / Wemoto and they were horrendously expensive. Bet its cost something daft like two hundred quid or even more for the 125 bits.
                        Strange then that All Balls make a kit for my DT200WR that includes everything across a couple of kits for around a hundred quid!
                        • NottsbikerN Nottsbiker
                          @Nottsbiker
                          Most stolen bike in the UK tax!...
                          If you checked the sizes I bet most bits are the same. The 200 does have an ally swing arm though, no?...
                            @Nottsbiker
                            NottsbikerN
                            NottsbikerN
                            @SpookDog yes the 200wr has an aluminum swingarm but so does my 125r (got a dt200r one) and I bet you are correct that loads of bits are the same.
                            Oddly though the the 200 is narrower than the 125 with the linkage mount a different distance from the pivot so would not be a direct swap either
