  4. My DT125 80s Yz style DT200 build one to watch!
233 Posts 17 Posters 118.3k Views 3 Watching
    @mhbikesnbits Yeah I would love to shave off as much weight as possible on my DTR.
    Another good one is to grab a lithium battery. That's a tremendous amount of weight saved!
    M Offline
    M Offline
    mhbikesnbits
    @Calum dam like the ideas , titanium bolts and lithium battery , really good ideas makes the wallet more empty tho 😂
    • M Offline
      M Offline
      mhbikesnbits
      All the important bits for the project are here loom , cdi , sevo and the other electrical goodies,
      Also the split pipe got some more work to do now ,l it’s mounting up
      • M Offline
        M Offline
        mhbikesnbits
        Would have been rude not give the pipe a ultrasonic bath after waiting so long to find one
        markus.wM B 2 Replies Last reply
        • M mhbikesnbits
          markus.wM Offline
          markus.wM Offline
          @mhbikesnbits wow that came up good.
          • M mhbikesnbits
            B Offline
            B Offline
            biohazard13
            @mhbikesnbits
            Shiny! What you gonna rust proof it with? Not sure if they were painted or plated from new?...
            Should of got him to send another ally swingarm while he was at it! Gold dust here...
            SpookDog...
            M 1 Reply Last reply
            • B biohazard13
              @mhbikesnbits
              SpookDog...
              M Offline
              M Offline
              mhbikesnbits
              @biohazard13 I haven’t seen one in picture before cleaned up tbh was thinking Of spraying it silver ro match the other bits of silver , if I’m honest got the pick of a lot of parts off the guy as I’ve gotten quite friendly with him so I’m going accumulate a lot of spares
              • M Offline
                M Offline
                mhbikesnbits
                Cheeky nos, must be pretty rare
                • M Offline
                  M Offline
                  mhbikesnbits
                  Concentrated on cleaning the casted finish off on the swing arm today the plan is to polish the smoother bit of the arm and keep the casted bit as norm to have less maintenance on the shine
                  • M Offline
                    M Offline
                    mhbikesnbits
                    Had this made it’s those little details that add thay extra shine sometimes alt text
                    • M mhbikesnbits
                      @mhbikesnbits Class touch 😉
                        M Offline
                        M Offline
                        mhbikesnbits
                        @Calum feels like it should be the last thing to put on but the headlight cluster will be in the way abit 😂
                        • M Offline
                          M Offline
                          mhbikesnbits
                          #224
                          I keep doing bits and researching bit and pieces but more and more work mounts ups hard to find the time sometimes , would like to get the swing arm done soon need the bearings for the suspension leg ordering and upgrade the rear shock for a YSS shock as a nice upgrade as the suspension really lacks front and back on the dts (I have nice trick up my sleeve for the front suspension), should have a nice base for the bike then and I can sit on a stand before it’s too heavy for lift off the table 😅
                          the Latest work I’ve done is take the tank back to bare metal quite lucky with my tank seems a real good one like not dented up and clean inside
                          • M Offline
                            M Offline
                            mhbikesnbits
                            #225
                            £500 for get my hubs drilled into brand spanking gold alloy 21 inch and 18 Inch rims with stainless spikes built and balanced not too shabby I don’t think
                            • M Offline
                              M Offline
                              mhbikesnbits
                              #226
                              Work in progress - side to side shot of how the loom is now and what it’s going to be like when it’s redone, crap weather has wrote off my plans to spray the swing arm after spending hours on prep this weekend too cold now
                              On the left is how the loom is now with crap sticky electrical tape and on the right is the work in progress loom fabric I’m doing
                              • M Offline
                                M Offline
                                mhbikesnbits
                                As part of the build I wanted to upgrade the spongy outdated suspension the dt125r has, one option I Did ponder was swapping the shock spring from the XT600 onto the DT shock but I decided the best upgrade in my opinion would be the YSS Shock, really looking forward to getting this on now I’ve seen it looks real sexy and got some nice adjustment options on it.
                                Gotta get this swing arm done!
                                • M mhbikesnbits
                                  @mhbikesnbits Very smart, I got a YSS on my RS and I'm happy with it. But I probably ought to consider an upgrade on the DTRE. It's always been good enough for my uses however, plus I have larger dog bones fitted so height wise it's spot on for me.
                                    M Offline
                                    M Offline
                                    mhbikesnbits
                                    @Calum you helped sway my decision tbh seen a few recommendations from you for the YSS on some old posts on here
                                    • M Offline
                                      M Offline
                                      mhbikesnbits
                                      Little update some minor changes, originally decided a Matt finish for engine hangers went with a gloss finish think it’s a improvement.
                                      Installed some electrics
                                      Still perfecting the swing arm put lots of work into it getting it to a perfect standard
                                      Had a little play making it look more like a bike😅
                                      • M Offline
                                        M Offline
                                        mhbikesnbits
                                        #231
                                        Took one for the team and purchased the expensive seal and bearing kit from eBay for the suspension knuckle.
                                        hopefully be able put together all the sizes for the forum so you can source it individually.
                                        Plenty of grease used inside.
                                        I used the method of threaded rod for install.
                                        Decided to install the shock to the frame also looking great on the bike I must say
                                        On a side note smart phone camera are great but sometimes pictures don’t speak a thousand words looks way better in person.
                                        Looking forward to getting some professional pictures done when complete
                                        • M Offline
                                          M Offline
                                          mhbikesnbits
                                          Opinions, are stainless steel zip ties overdoing it for the loom ?
