  3. Top End
  4. Athena 170 porting
Athena 170 porting
11 Posts 7 Posters 4.4k Views
  • T
    T
    theportingmaster
    The first people with a 170 kit lifted the cylinder 3mm, hence the terrible torque curve..but from then on the myth that the 170 kit needed 'port adjustment' was set in stone..while it benefits from porting, lifting the whole lot 3mm is a bad idea...The Athena 170 cylinder is the same casting as the 125 but bored out to 65mm. Most people reported a good increase in bottom end grunt but no real gain at peak hp. It turns out this is mainly due to the cylinder casting being the same as their 125cc cylinder, so has 125cc sized ports.
    I opened them up to 170cc sized ports by widening the exhaust
    5mm, and lifting the transfers 1mm using a 1mm base spacer
    and 1mm skimmed of the top of cylinder. It is better raising the
    cylinder rather than modify the transfer ports as the Nicasil
    plating chips easily.
    Double check the pv cable setting. On mine with the pulley
    lined up with the mark, it was only about 3/4 open. Only when
    I looked up the port did I spot why it felt so flat initially!
    Initially the 170 kit felt awful, until I double checked the pv
    setting and found it was about 3mm closed. Once that was
    reset, it flew...
    declanD MadGyverM 2 Replies Last reply
    4
    • T theportingmaster
      reset, it flew...
      @theportingmaster nice info thank you
        reset, it flew...
        MadGyverM
        MadGyverM
        @theportingmaster Reading your post is almost like reading my final calculations,little different numbers by +0.1mm,I did not skimmed the cylinder.
        I did work on crankcases,transfers,exhaust,exhaust port,pv,cylinder head(compression,squish,volume) and custom gaskets.
          If you're porting the 170 then the plating has to come off, which is really the only reason why I haven't done mine yet. I will do it, but after a season of riding it. Seems criminal to destroy good plating.
          MadGyverM 1 Reply Last reply
            MadGyverM
            MadGyverM
            @calum No destruction to the plating,everything was done very slow and carefully,the edges are very smooth.
            Only sandpaper (dremel and hand) was used,it took A LOT of hours.If I used dremel carbide bits or sandstone it was faster but risky.
            • L
              L
              lllDennis
              How much of a diffrence did the 5mm widening of the port make?
              I've just completely rebuild my engine. (Gearbox, bearing, new piston) Already have 320km's on it and it's pretty solid. The 170 kit is a huge improvement over the 125. Is it worth messing with the ports? ☺
              • L lllDennis
                MadGyverM
                MadGyverM
                @llldennis How much should the port for the 65mm bore,47mm wide (43 in chordal length).It's 42mm like the stock cylinder.
                Worth messing,no and yes,what you after is the right question.
                • R
                  R
                  Rallyfinnen
                  I received my 170 kit recently and had a look at port timings etc, so here are my thoughts:
                  As mentioned above, the ports seem basically the same as on the 125 Athena. However, on the Athena 125 that came on the bike when I bought it, I had a thin metal head gasket, but the 170 kit came with a 1mm+ thick head gasket. Not sure if the 125 kits come with such a head gasket too? Using a head gasket that thick would make the port timings even worse on my new 170kit when squish is set correctly, and I don't know of any thin metal head gaskets that fit the 170 cylinder diameter? Could there be some DT175 thin gaskets that could be used?
                  I decided it was not even worth mounting it in the stock form, with transfer durations around 110deg (or was it less, can't remember now), and also a lot of port area is covered by the piston. IMHO they should be 120-130deg. Fully open they would be over 130 though. However, exhaust duration seems ok out of the box, and gets a bit high with the cylinder raised. I would prefer staying under 190. Based on the high duration I don't want to widen it at this point, thinking blow down area should be sufficient as is, and I'm not aiming for a really high revving engine.
                  I put the head insert in the lathe and removed 1,4mm, and made some spacers from 1,4mm sheet aluminum to put between the insert and the head. This way it's easily reversible by replacing the insert and removing spacers.
                  For now I'm waiting for a piston pin needle bearing, since the one delivered with my kit was only 17.4mm wide (from Götz Germany), and I ordered a 22mm wide bearing separately. Inside with of the piston is abt 23mm.
                  I also made some small rectification to the ports, removing sharp edges, and also matching of the exhaust port to the power valve. There was a couple mm step/shape mismatch with the power valve in the open position, so I removed some material in the upper part of the exhaust port towards the header-flange.
                  • R
                    R
                    raaracing
                    Does someone have any pictures of the porting and spacing the cylinder? What crank are you using?
                    • R raaracing
                      @raaracing I need to do this, I do have a LIDAR sensor and a spare Athena 170 barrel. The plan was to scan my two stroke barrels into models etc.
                      • R
                        R
                        Rallyfinnen
                        The spacer I used was just a 1,5mm thick alu sheet that I cut to the shape of a base gasket. Remember the head has to be 'moved down' too, to keep the squish nice and tight. Can be done by machining the top of the cylinder down, or machining the head.
                        IMHO the head volume is too low from factory, and combustion chamber needs to be enlarged to have a safe CR if squish is below 1mm as I want it (0,8mm now). The 125 and 170 inserts seem to be the same from Athena..
                        No porting done on mine. I think widening the upper part of the exhaust could add some power at higher revs and keep the low band pretty much the same. Pretty easy to do a portmap on paper, but I did not do it before I installed the cylinder. Just measured the port height and calculated the port timings to get a rough idea what height I should try. Raising it the full 3mm to get the 'full opening' of the transfers gives pretty wild port timings, but it would probably work with custom ignition curve and pipe to make it a screamer (power at high revs). Not what I'm after though. Pretty happy with it as it is now.
