  4. Regulator/rectifier went up in smoke
15 Posts 4 Posters 3.5k Views
    Had a VERY similar problem from an eBay regulator on my Aprilia RS 125. The RS has a built in Voltmeter and the regulator was putting out 19 volts into my lithium battery. This eventually went up in smoke.
    I didn't realise that this was a Chinese regulator as it was £40 and thought that was about right for a genuine one, which turned out to be more like £100.
    So I'd put money on the aftermarket regulator, get a used genuine one.
    DTGREENLANER
      DTGREENLANER
      @Calum and
      Thanks for getting back to me both of you
      Ah right…Does sound like it most likely was the cheap regulator then. And potentially the clicking starter solonoid didn’t help.
      I’ve actually just went up the loft to my box of DT125X spares and come across another regulator with the same stamp on the back as my old original one so hopefully that should do the trick. Also rather than using my aftermarket starter solonoid which just got delivered I’ve just found a spare original one.
      In my box of spares there’s also a spare loom with the 4 pin plug I will need. Before I chop it off to use, do you know if I can buy this plug online? To save chopping a good condition loom
      I’ve linked pictures and the plug I could do with.
      https://ibb.co/CvcYKw2
      https://ibb.co/b6Rg8Sm
      https://ibb.co/DL7TY4x
      https://ibb.co/nbrmMLT
      https://ibb.co/hKZgmym
      https://ibb.co/64X9c3v
      https://ibb.co/z8LJsVY
      Cheers
      • D DTGREENLANER
        @Calum and
        Cheers
        @DTGREENLANER
        I’ve never found a compatible one. But they are common as fux. Do a search for ‘rectifier female socket motorcycle’ or similar…
          @DTGREENLANER
          Or male! They’re all over the place for £6
          Can’t remember how many pins, 4 or 6 but there’s loads out there…
          • MadGyverM
            MadGyverM
            @DTGREENLANER
            Did you cross-reference with other Yamaha models,this company does it a lot and uses same parts to other bikes with just another part number.I think the XT's (400-500-600) use the same.
              DTGREENLANER
              Had a quick look atm but struggling to find anything similar atm that would fit. All different styles isnt there and you have to remember the regulator pins have a plastic wall around them so would probably need to modify that as well and different style might not stay on where it most likely wont fit the same ‘locking pin bit on the reg’
              Will keep looking and worse comes to worse I’ll just chop it off this spare loom lol.
              • MadGyverM MadGyver
                @DTGREENLANER
                DTGREENLANER
                @MadGyver
                Thanks for that. I didn’t think about doing that.
                I just checked and part numbers for regualtor / Rec on dt125re are
                1D0H196001
                Replaces 1D0-H1960-00
                Will look tomorrow I I can find other models using the same part
                As mentioned above though I won’t need to buy another regulator if the spare I have works fine but definitely good idea if not or if something breaks in the future
                Cheers
                • D DTGREENLANER
                  DTGREENLANER
                  @DTGREENLANER
                  Someone just sent me this , need to have a better look tomorrow, just at work
                  Might find it on here
                  Replacement plugs and connectors.
                  https://www.zeeltronic.com/page/connectors.php
                  • D DTGREENLANER
                    @MadGyver
                    1D0H196001
                    Cheers
                    DTGREENLANER
                    @DTGREENLANER
                    Looks like I got it sorted hopefully.
                    Yamaha Facebook group got reccomened some companies.
                    Will post links up for anyone else in the future and will update if works
                    https://kojaycat.co.uk/epages/950000457.mobile/sec66767ef64f/?ObjectPath=/Shops/950000457/Products/US4W-BLK-Conn - I chose this one US4W-BLK-Conn
                    Also other product numbers for above website :
                    4W-250-CNA , 4W-CNA-NAT
                    Then another website below got linked this which might work
                    https://www.automotiveconnectors.com/4-way-sumitomo-250-type-female-60mm250-black.html
                    • D DTGREENLANER
                      @DTGREENLANER
                      @DTGREENLANER
                      Cheers for posting that. Handy as fux, I plan on swapping my probably Chinese RR out for a later type one like yours. I didn’t even spot that the plugs are different…
                      Saved me a lot of searching. I did not realise how many different kinds are out there!…
                        @DTGREENLANER
                        DTGREENLANER
                        Sorry late reply, only got round to putting new plug on the other day but yeah no worries man
                        Replacement plug worked nicely. I replaced the regulator/rec and starter solenoid with oem parts as well and started lovely off the button. No more clicking from the starter solenoid or dodgy aftermarket rectifier going up in smoke
                        Cheers
