    It’s a weird one! I cleaned the carb out again. Another tiny little bead of shitty/water in the bottom of the bowl. Not even half a match head. Less than usual.
    This time I junked the air filter because it was starting to disintegrate. I thought I had a good NOS one but that was crumbling as well! It’s definitely running and picking up a lot better without the old filter. Seems it’s down to the fact that it really doesn’t like the damp atmosphere this weather is making. Way too humid…
    Too much rain! I didn’t even consider a low pressure atmosphere!…
    It used to really love the cool dry early 5o’clock morning air a few months ago! You could really feel the extra whump to each charge of mixture. Especially at low rpms…
    #713
    I need a gudgeon/wrist pin for the Athena piston. Anyone have an old one spare or know where to get? I need to know the size as well. if I have to order 1 …
    I believe it’s 55mm x 15mm but am not 100% sure…
    OllieDTRO 1 Reply Last reply
      OllieDTRO
      OllieDTRO
      OllieDTR
      This for the 170kit mate?
      Think I’ve got a spare I’ll check for you
      • OllieDTRO OllieDTR
        @OllieDTR
        Yeah! It’s for the Athena 170 piston. If you got one it’d be sweet 🙂 …
        • MadGyverM
          MadGyverM
          @SpookDog I think it's the same size pin as the Yamaha YFS200 Blaster piston.
          • MadGyverM MadGyver
            @MadGyver
            That sounds probable. Same size piston but with a longer stroke to take it up to the 200cc
              @MadGyver
              Can someone please measure the piston/gudgeon/wrist pin for the Athena 170cc kits piston?
              I’m getting conflicting information from the web about them…
              If anyone has an old spare unused one, please sell it to me or at least measure the thing! Please!
              I’m guessing that the diameter is the same as the standard pin if it uses standard small end bearings? Just the length would be different?
              I don’t have the tools to measure the pistons interior myself…
                OllieDTRO
                OllieDTRO
                OllieDTR
                Hi bud
                Send me your address in messages and I’ll send it out! Sorry I completely forgot to busy ripping on my dt😂
                S 2 Replies Last reply
                • R
                  R
                  Rallyfinnen
                  I don't have the possibility to measure, but the diameter of the 170 pin is the same as stock, but it's longer. It's also lightened with a conical bore, so thinner walls towards the ends. I would not recommend a stock needle bearing with the 170-kit, there will be too much axial play on the bearing, so it can wander out of position. I had a lot of trouble finding a suitable needle bearing for mine.
                  • MadGyverM
                    MadGyverM
                    #721
                    @Rallyfinnen
                    @SpookDog Small end bearing from the YFS200 Blaster is the proper one,fits like a glove. I have it on mine.
                    The stock has too much play on the 170kit,as mentioned above.
                      Hi bud
                      @OllieDTR
                      Sent my siss’s address. It’s where all my tools and spare parts are! Well a dry place to work anyways 🙂 …
                      Cheers for the info guys, will try and measure the gap in the inside of the piston for the little end bearing width…
                      The roads we’re actually dry today. My bike actually felt like it was revving and pulling properly for the first time since it started pissing down with rain every day!…
                      🙂 nice!…
                      • Hark_PtooieH
                        Hark_PtooieH
                        Hark_Ptooie
                        No expert in bearings, but are they not usually having rather standard measurements? Such as "Ø20 mm inside, Ø30 mm outside, 20 mm wide" and then graded by various tolerance requirements?
                        If so - why do everybody post like "you need the bearing from a 1989 model XYZ345" instead of "SKF #7709 or equivalent from any of a dozen manufacturers"? Not sniping at Rallyfinnen here, it is a general observation from way back.
                        I mean, these guys have thousands of sizes and models on the shelves that I can obtain within a week from local suppliers. That would be far easier than trying to track down a certain model built a certain year in a certain region.
                        https://catalog.skfusa.com/data/bbm19enu/011/html/export/SKF Bearings and Mounted Products.pdf
                        That's 579 pages of normal bearings, there are droves of specials as well.
                        • Hark_PtooieH Hark_Ptooie
                          @Hark_Ptooie
                          I know what you’re saying, in most cases there are markings. Though I think they’re usually maker specific. Not noticed any on small end bearings, though never purposely looked for them…
                          What is SFK short for ?…
                            @Hark_Ptooie
                            #725
                            I’ve just found a place near me that does TiG welding on cast aluminium casings! So I can go ahead and get my early 600&something numbered engine case lug welded! I’ve got new main bearings on the way! I’ve just got to replace the oil seals I used on the Tzr lump, as well as an Athena head gasket.
                            I did want to wait until the Tzr was rideable so I could get the Dtr frame stripped, dipped & coated. It’s going to take me longer than I thought though, and I’m not sure how long the engine is going to last! It was only a lashed together mismatch of parts supposed to get me to the next rebore! But the suspect conrod put paid to just doing a top end rebuild…
                            Also found a vapour blasting place local as well, shiny casings!! 😜 …
                              #726
                              Hmmm! Got a good winter hours snaggle, my headlight ‘stops’ when I turn the bars to a certain angle. It doesn’t affect when normal riding, just when manoeuvring back & forth, left to right and the like. So I never really noticed it before…
                              Not so handy when it’s getting darker by the day! 🫤 …
                                #727
                                Red & yellow stripe feed wire to the headlight was just kinda ‘smooshed’ up into place at one of the idiot proof connectors. How it was still working is a mystery to me. No wonder my headlight dimmed when I put on the brakes!…
                                Other thing was a red wire at another connector was doing the same business! It was basically responsible for all the battery operated shizness! It’s another wonder that the PV cycled when I turned the key on! The wire fell off when I removed the headlight (along with the red/yellow stripe wire) stopping the PV from cycling, the brake light, indicators, horn, ect, from working!
                                Basically both my AC & DC circuits were running by a hair! (Or gravity!!) Thank fux the ignition curcuit is sound! I hope!! 😇 …
                                At least now I’ve bodged it the lights and horn ect are bright and truer than they’ve ever been. For now until the test ride anyways 😐 …
                                Till next time…
                                  Till next time…
                                  @SpookDog @HOTSHOT-III Posted some really helpful pictures, but unfortunately they squashed as I had to restore the database...Sorry bud, was a really useful post though.
                                    @Calum Thanks bud, I wondered what happened to that post, just seen you've been fixing the forum all day 👍
                                    @SpookDog Here are some cable routing schematics from the Yamaha repair manual, the wiring behind the headlight is a bit of a rat's nest like most trail bikes but this should help you out. Also considering the time of year and the weather we've been having, it's well worth giving the wiring behind the headlight (and under the tank) a thorough blast with WD40 . Throw old towels or dust sheets over both wheels to protect the tyres and brakes, then apply in the manner displayed by the gentleman in the final image. You can also fill up the handlebar switches until it flows out of every orifice, it's a harsh environment for a switch but by doing this regularly you can make the switches last the life of the bike
                                      #730
                                      We walk the Earth, like Jolly Green Giants! But with Guns!!…
                                      Stay Frosty!…
                                      Did a test ride: Lights are good! Even the engine is crisper since the PV seems to be kicking in properly!…
                                      I could of done with routing pics years ago, but they be always welcome 😜 …
                                      Cheers!…
                                        Is that manual available online? Or do you own the book? I didn’t know that there was an official workshop manual for the Dtr…
                                        PS you still got the wheels for sale?…
                                          @SpookDog Here you go bud, it was the official dealer manual in 1988:
                                          https://www.ebay.co.uk/itm/323952533497?hash=item4b6d135ff9:g:8mgAAOSw8A1dqtdu&amdata=enc%3AAQAIAAAA0J7povBA%2Fed02ZQWQaloCPHXV9GkRuofT9DZVVp%2BbiuZl6AVamwQCANMTldfO39qzx9CoE1xjcXGtzWtYOLa48iErMAfaeeFL%2B8Ee%2BmjpaRTflmyAenChVIiUQalQM3peHJ2%2Bv1gblqHb%2F86QS6hsY4RvN8OIFKkTrYtH4X1AK2gK%2BAfPKQYAOYtJVuIBwQ0aqOJhDSZog4qRkLPYOfBvRwRikbIP%2FQ4ylJERGtrmNAHoUC%2FpW140AmrFjE1ENEJKq3gt8g0ZpS%2FyzMcYNrfA2A%3D|tkp%3ABk9SR8Lrpaz4Yg
                                          Obviously you have to be a bit careful because all the engine specs are for the 3DB round slide carb model but the cycle parts are essentially the same on all DTRs right up to 2003. Lots for sale online though, I was able to find an '89 3MB DTRe version with a full colour wiring diagram for about £20 I think.
                                          And some of the torque settings are frankly ludicrous; for example 20Nm for the disc bolts is off the scale for M6. I destruction tested an old rear one using a spanner in the vice and the 4mm allen head rounded at 16Nm so I did mine on the bike to 12 rear and 14 front and they never moved. However it does show it's wise to invest in genuine bolts or their equivalent for anything structural as a stainless Xmas tree decoration bolt would probably fail at around half that.
                                          Wheels sold a couple of weeks ago I'm afraid, maybe talk to Salisbury Wheel Builders in Ringwood?
