1.1k Posts 26 Posters 668.0k Views
    PJME. Never needed an O-Ring upgrade. I've not had any issues with the head gaskets for my 170 kit.
    • MadGyverM
      MadGyverM
      #703
      @SpookDog All Athena kits i've seen are with gasket. The o ring head is custom.
      I 'm not fan of this type of sealant for a combastion chamber,good only for competition with frequent rebuilds.
        @MadGyver The O-Ring sits between the skull-cap and head cylinder head.
        • MadGyverM
          MadGyverM
          @Calum I thought he meant the o-ring groove they do on cylinder head for replacing the gasket with o-ring.
            Ah right. No, I didn't realise that the Athena kit used an O Ring for the above and consequently it leaked coolant 🤣
              I though you had an oring conversion on your kit?
              I didn’t know that they all used gaskets , doh!
                I’ve been getting a niggle the last few days. When I fitted a new pilot jet a month or three ago the rev pickup was so much improved that my little bike was actually popping unintentional little wheelies when I was pulling away, even cold. Just lately it’s been getting unresponsive, you can hear the ‘bore noise’ from the carb without the engine picking up. If that makes sense?
                Any ideas wtf it’s caused by?
                I’ve been getting crap in the carb problems forever, usually it’s the pilot that gets affected. Does this sound like main jet obstruction?
                Any help, Yada ~ yada…
                  My Cagiva is running like shit at the moment.
                  Built that engine the summer and it was legit rapid. Went to Belgium a few weeks ago and come back and the bike ran so bad. Spent the last two weekends jetting it. It can't be the fuel since that's the same before I went to Belgium, however the temperature has dropped...
                  • OllieDTRO
                    OllieDTRO
                    OllieDTR
                    Might have to upjet in this weather mate, my French import bike loved to run on 210 in summer and 22.5 pilot when winter came, didn’t like it at nightime I had to go up one jet on each
                      #711
                      It’s a weird one! I cleaned the carb out again. Another tiny little bead of shitty/water in the bottom of the bowl. Not even half a match head. Less than usual.
                      This time I junked the air filter because it was starting to disintegrate. I thought I had a good NOS one but that was crumbling as well! It’s definitely running and picking up a lot better without the old filter. Seems it’s down to the fact that it really doesn’t like the damp atmosphere this weather is making. Way too humid…
                      Too much rain! I didn’t even consider a low pressure atmosphere!…
                      It used to really love the cool dry early 5o’clock morning air a few months ago! You could really feel the extra whump to each charge of mixture. Especially at low rpms…
                      • OllieDTRO OllieDTR
                        @OllieDTR I think it was running savagely rich and now it's not atomising.
                        Anyway, yeah weather can affect it.
                          #713
                          I need a gudgeon/wrist pin for the Athena piston. Anyone have an old one spare or know where to get? I need to know the size as well. if I have to order 1 …
                          I believe it’s 55mm x 15mm but am not 100% sure…
                          OllieDTRO 1 Reply Last reply
                            OllieDTRO
                            OllieDTRO
                            OllieDTR
                            This for the 170kit mate?
                            Think I’ve got a spare I’ll check for you
                              @OllieDTR
                              Yeah! It’s for the Athena 170 piston. If you got one it’d be sweet 🙂 …
                              • MadGyverM
                                MadGyverM
                                @SpookDog I think it's the same size pin as the Yamaha YFS200 Blaster piston.
                                • MadGyverM MadGyver
                                  @MadGyver
                                  That sounds probable. Same size piston but with a longer stroke to take it up to the 200cc
                                    @MadGyver
                                    Can someone please measure the piston/gudgeon/wrist pin for the Athena 170cc kits piston?
                                    I’m getting conflicting information from the web about them…
                                    If anyone has an old spare unused one, please sell it to me or at least measure the thing! Please!
                                    I’m guessing that the diameter is the same as the standard pin if it uses standard small end bearings? Just the length would be different?
                                    I don’t have the tools to measure the pistons interior myself…
                                      OllieDTRO
                                      OllieDTRO
                                      OllieDTR
                                      Hi bud
                                      Send me your address in messages and I’ll send it out! Sorry I completely forgot to busy ripping on my dt😂
                                      S 2 Replies Last reply
                                      • R
                                        R
                                        Rallyfinnen
                                        I don't have the possibility to measure, but the diameter of the 170 pin is the same as stock, but it's longer. It's also lightened with a conical bore, so thinner walls towards the ends. I would not recommend a stock needle bearing with the 170-kit, there will be too much axial play on the bearing, so it can wander out of position. I had a lot of trouble finding a suitable needle bearing for mine.
                                        • MadGyverM
                                          MadGyverM
                                          #721
                                          @Rallyfinnen
                                          @SpookDog Small end bearing from the YFS200 Blaster is the proper one,fits like a glove. I have it on mine.
                                          The stock has too much play on the 170kit,as mentioned above.
