  • MadGyverM
    MadGyverM
    The DTR of course!
    • MadGyverM
      MadGyverM
      Is it the one from ebay recently posted to another thread?
      • MadGyverM MadGyver
        #700
        @MadGyver
        Sorry for tardy reply, yes it is £155 posted.
        Are all 170 Athenas fitted with an o-ring head? Or are some fitted with a gasket?…
        Yeah, it’s going to live on the Dtr…
          @MadGyver
          Can anyone please let me know where I can get head gaskets for the 170 top end?
          Also if there are o-ring upgrades?..
          Ta!
            PJME. Never needed an O-Ring upgrade. I've not had any issues with the head gaskets for my 170 kit.
            • MadGyverM
              MadGyverM
              #703
              @SpookDog All Athena kits i've seen are with gasket. The o ring head is custom.
              I 'm not fan of this type of sealant for a combastion chamber,good only for competition with frequent rebuilds.
                @MadGyver The O-Ring sits between the skull-cap and head cylinder head.
                • MadGyverM
                  MadGyverM
                  @Calum I thought he meant the o-ring groove they do on cylinder head for replacing the gasket with o-ring.
                    Ah right. No, I didn't realise that the Athena kit used an O Ring for the above and consequently it leaked coolant 🤣
                      I though you had an oring conversion on your kit?
                      I didn’t know that they all used gaskets , doh!
                        I’ve been getting a niggle the last few days. When I fitted a new pilot jet a month or three ago the rev pickup was so much improved that my little bike was actually popping unintentional little wheelies when I was pulling away, even cold. Just lately it’s been getting unresponsive, you can hear the ‘bore noise’ from the carb without the engine picking up. If that makes sense?
                        Any ideas wtf it’s caused by?
                        I’ve been getting crap in the carb problems forever, usually it’s the pilot that gets affected. Does this sound like main jet obstruction?
                        Any help, Yada ~ yada…
                          My Cagiva is running like shit at the moment.
                          Built that engine the summer and it was legit rapid. Went to Belgium a few weeks ago and come back and the bike ran so bad. Spent the last two weekends jetting it. It can't be the fuel since that's the same before I went to Belgium, however the temperature has dropped...
                          • OllieDTRO
                            OllieDTRO
                            OllieDTR
                            Might have to upjet in this weather mate, my French import bike loved to run on 210 in summer and 22.5 pilot when winter came, didn’t like it at nightime I had to go up one jet on each
                              #711
                              It’s a weird one! I cleaned the carb out again. Another tiny little bead of shitty/water in the bottom of the bowl. Not even half a match head. Less than usual.
                              This time I junked the air filter because it was starting to disintegrate. I thought I had a good NOS one but that was crumbling as well! It’s definitely running and picking up a lot better without the old filter. Seems it’s down to the fact that it really doesn’t like the damp atmosphere this weather is making. Way too humid…
                              Too much rain! I didn’t even consider a low pressure atmosphere!…
                              It used to really love the cool dry early 5o’clock morning air a few months ago! You could really feel the extra whump to each charge of mixture. Especially at low rpms…
                              • OllieDTRO OllieDTR
                                @OllieDTR I think it was running savagely rich and now it's not atomising.
                                Anyway, yeah weather can affect it.
                                  #713
                                  I need a gudgeon/wrist pin for the Athena piston. Anyone have an old one spare or know where to get? I need to know the size as well. if I have to order 1 …
                                  I believe it’s 55mm x 15mm but am not 100% sure…
                                  OllieDTRO 1 Reply Last reply
                                    OllieDTRO
                                    OllieDTRO
                                    OllieDTR
                                    This for the 170kit mate?
                                    Think I’ve got a spare I’ll check for you
                                      @OllieDTR
                                      Yeah! It’s for the Athena 170 piston. If you got one it’d be sweet 🙂 …
                                      • MadGyverM
                                        MadGyverM
                                        @SpookDog I think it's the same size pin as the Yamaha YFS200 Blaster piston.
                                          @MadGyver
                                          That sounds probable. Same size piston but with a longer stroke to take it up to the 200cc
