1.1k Posts 26 Posters 667.4k Views
    Rear master to reservoir outlet turned up today, at last! Strangely enough the 1/2 master has ‘settled in’ and is providing enough fluid to the 35mm front calliper that I’ve fitted to the back. Go figure!…
    Had to clean out the carb again today, namely water globlet in the pilot jet as usual. I don’t understand why I suffer from this so often. New petrol cap time, maybe?…
    R
    R
    R3L3_89
    @SpookDog cover the gas tank cap with electical tape, I did that as soon as I got my bike, the keyhole can leak. It's not likely someone will try to steal your gas and it's inconvenient to lock and unlock the tank every time you need to fill it up which happens too often with this thing for some reason
      What to do, what to do with you! Hmm?…
      The Dtr?
        I must admit, I have really changed my tune with the 170 kit.
        What I would say is, make sure the powervalve is ported flush. Genuinly mine protruded the exhaust port stock. So benefits from modding the valve even if you leave the exhaust port alone.
        I think the DTR is a better choice for the 170. Just because you're more likely to be utilising the benefit from the bottom end more due to the nature of the bike.
        TZR is more of an open stretch bike where you'll want more HP up the top end.
        • MadGyverM
          MadGyverM
          The DTR of course!
          • MadGyverM
            MadGyverM
            Is it the one from ebay recently posted to another thread?
            • MadGyverM MadGyver
              #700
              @MadGyver
              Sorry for tardy reply, yes it is £155 posted.
              Are all 170 Athenas fitted with an o-ring head? Or are some fitted with a gasket?…
              Yeah, it’s going to live on the Dtr…
                @MadGyver
                Can anyone please let me know where I can get head gaskets for the 170 top end?
                Also if there are o-ring upgrades?..
                Ta!
                  PJME. Never needed an O-Ring upgrade. I've not had any issues with the head gaskets for my 170 kit.
                  • MadGyverM
                    MadGyverM
                    #703
                    @SpookDog All Athena kits i've seen are with gasket. The o ring head is custom.
                    I 'm not fan of this type of sealant for a combastion chamber,good only for competition with frequent rebuilds.
                      @MadGyver The O-Ring sits between the skull-cap and head cylinder head.
                      • MadGyverM
                        MadGyverM
                        @Calum I thought he meant the o-ring groove they do on cylinder head for replacing the gasket with o-ring.
                          Ah right. No, I didn't realise that the Athena kit used an O Ring for the above and consequently it leaked coolant 🤣
                            I though you had an oring conversion on your kit?
                            I didn’t know that they all used gaskets , doh!
                              I’ve been getting a niggle the last few days. When I fitted a new pilot jet a month or three ago the rev pickup was so much improved that my little bike was actually popping unintentional little wheelies when I was pulling away, even cold. Just lately it’s been getting unresponsive, you can hear the ‘bore noise’ from the carb without the engine picking up. If that makes sense?
                              Any ideas wtf it’s caused by?
                              I’ve been getting crap in the carb problems forever, usually it’s the pilot that gets affected. Does this sound like main jet obstruction?
                              Any help, Yada ~ yada…
                                My Cagiva is running like shit at the moment.
                                Built that engine the summer and it was legit rapid. Went to Belgium a few weeks ago and come back and the bike ran so bad. Spent the last two weekends jetting it. It can't be the fuel since that's the same before I went to Belgium, however the temperature has dropped...
                                • OllieDTRO
                                  OllieDTRO
                                  OllieDTR
                                  Might have to upjet in this weather mate, my French import bike loved to run on 210 in summer and 22.5 pilot when winter came, didn’t like it at nightime I had to go up one jet on each
                                    #711
                                    It’s a weird one! I cleaned the carb out again. Another tiny little bead of shitty/water in the bottom of the bowl. Not even half a match head. Less than usual.
                                    This time I junked the air filter because it was starting to disintegrate. I thought I had a good NOS one but that was crumbling as well! It’s definitely running and picking up a lot better without the old filter. Seems it’s down to the fact that it really doesn’t like the damp atmosphere this weather is making. Way too humid…
                                    Too much rain! I didn’t even consider a low pressure atmosphere!…
                                    It used to really love the cool dry early 5o’clock morning air a few months ago! You could really feel the extra whump to each charge of mixture. Especially at low rpms…
                                    • OllieDTRO OllieDTR
                                      @OllieDTR I think it was running savagely rich and now it's not atomising.
                                      Anyway, yeah weather can affect it.
                                        #713
                                        I need a gudgeon/wrist pin for the Athena piston. Anyone have an old one spare or know where to get? I need to know the size as well. if I have to order 1 …
                                        I believe it’s 55mm x 15mm but am not 100% sure…
                                        OllieDTRO 1 Reply Last reply
                                          OllieDTRO
                                          OllieDTRO
                                          OllieDTR
                                          This for the 170kit mate?
                                          Think I’ve got a spare I’ll check for you
