1.1k Posts 26 Posters 649.4k Views
    So it’s the piston that the balancer shaft balance’s? I’d of thought Athena or some other enterprising soul (with access to a lathe) would of made up and sold a batch of ‘big bore balancer bits’ by now! 🙂 …
    I thought it was the crank, for some reason…
    MadGyverM
    MadGyverM
    Or you can use the DT200R 3ET balancer that fits like a glove,but then you are limited to the big bore kit along the heavy gudgeon pin you have.
    It's a mod I thought to do but I didn't have the vibrations I expected.
    • MadGyverM MadGyver
      @MadGyver
      I like your thinking! Nice idea, cheers bud…
      I kinda thought that the numb fingers was an age thing anyways. I can remember driving Mk1 transit LWB with no power steering & drum brakes back in the 90’s.
      Vibration is a minor niggle really 🙂 Saying that I’d rubber mount the bars if I could!…
      Anyone got a spare clutch cable mount that lives on the bottom of the barrel stud that they can post? I’m skint till next Wednesday…
        @MadGyver
        #789
          @MadGyver
          #790
          Damn it! I didn’t realise that there is an oil seal under the 2T pump drive cog, on the inside of the clutch casing. Every other bloody seal is listed apart from that one! 21 x 10 x 5
          Got to wait for one to turn up now before I can button up the clutch casing…
          I’ve replaced every other seal & bearing, so I’m not going to use the old one!…
          Sometimes it feels like the ‘Little people’ are fuxin with me! 🧚‍♀️ …
            @SpookDog I think you get one of those with the Yambits oil pump repair kit
              Can you please link me to it? I’ve tried but can’t seem to ‘find anything’ 😐
              I’d like to know what price is on the kit, as well as what’s included…
              I’ve already gotten the casing oil seal. I don’t want to put on any of the pumps I’ve got without giving them a ‘refresh’ though!…
                #793
                Don’t worry! I’ve found it 2 minutes later! 🤕
                If the rain holds off for the next day or two: I should be able to fit the seals and button up the clutch side. I’ve already prepped it with a hot detergent wash and ‘scrub/brush’ it’s just degrease assemble and fit. Same with the barrel and piston. I’ve already decoked the piston and PV and barrel-exhaust port…
                I haven’t found suitable bolts for the reed cage and inlet yet. I won’t fit the top end till that’s fitted and plugged with clean cotton waste…
                One good day or two ‘meh!’ days and I’m ready to give the bike a few soaks with shampoo detergent before getting a final jet wash. Then I can swap out the motors while fitting a new (used) rear shock…
                I still haven’t finished fitting the bottom headstock bearing to the replacement yoke! It got stuck halfway and I didn’t want to force it ‘unreasonabley’ 🙂 I can’t throw anymore heat at it because it’s got a built in oil seal! So, because I don’t know anyone with an hydraulic press, I need to find a suitable sized tube to ‘beat it on squarely’ 😜
                I’d kinda gotten used to the ‘clicky’ front end because it tracked truly, unlike before when it used to favour a few degrees to the left or right ‘Unsafe at any speed over 40’ springs to mind!…
                  Any tips on fitting the Athena head? Is the inner cap supposed to be a tight or a loose fit? It took a bit of heat to separate it from the outer head-cap. I’d imagine that it’s a ‘good’ fit that is held in place by the rubber seal around the spark plug section?
                  Be nice to know tho! 😜 …
                    The athena head drops into the skull cap as a snug fit, then miraculously becomes a nightmare to remove 🤣 At least that was my experience.
                      #796
                      Cheers bud! That’s is actually very helpful!…
                      OMG! I have fallen in love with Permatex Copper gasket spray! Why haven’t I found this before? It really is the mongrels dangles! Perfect application 😇
                      • MadGyverM
                        MadGyverM
                        #797
                        @SpookDog Permatex Copper gasket spray,if needed It can be easily removed with nitro thinner.
                          @MadGyver
                          Nitro, What is dat? Model fuel?…
                          S MadGyverM 2 Replies Last reply
                            @MadGyver
                            #799
                            Do the piston rings go a particular way on an Athena piston? I can’t see any difference between them. The only thing that might be a marking is a [ kind of shape, but horizontal. That’s only on one ring though…
                            CalumC S 2 Replies Last reply
                              @SpookDog No? I just put them in so that the text was facing upwards and that the ring end gaps met the dowels in the piston grooves.
                              Wossner are notorious for leaving one of the ring end gaps out of spec, gives the fitter flexibility to dial it in. The Athena ones I done recently were both spot on, but needless to say, you should check it against the spec.
                                Oh well, I chucked it on anyways!…
                                I did have help from a friend though…
                                Taught me how to feather the throttle 🙂 …
                                  Don't chuck it on FFS! Amatuers! Place it on lovingly. Caress it, hold it, love it!
                                  Does look good though! I mean fair play to you and your workbench! You're doing it guerilla stylie.
                                    #803
                                    Chuck is a term of affection from me! 🙂 Seriously! All new bearings and seals throughout, new Jamasil crank. I can’t afford to be ‘blasé’ 😳 I even removed, cleaned the threads, greased and re-inserted the barrel base studs and dowels to a tightness that they’re removable in the future, if needs be. The head studs I always remove and service…
                                    Labour of Dove 🤔 …
                                    It’s getting there! Little by little, weather permitting…
                                    WTFux! it’s just started raining! 🤪 …
                                      Doing a great job bud! Keep it up.
                                        #805
                                        The umbrella? 😜 …
                                        Blaster 200 small end bearing didn’t fit. Was too wide to fit inside the piston. Luckily I had a dtr bearing that has wider roller/needles than the others I’ve got. Even with a bit of side to side play it still has good coverage of the conrods top eye width…
                                        PS I just noticed that the Athena top end gasket set doesn’t include the orange PV bush seal! For nearly £50 you’d think they’d include it?!…
                                          The umbrella? 😜 …
                                          #806
                                          Ready to drop in. All torqued and tight! Only the 2T pump left to fettle, I’ve got 3 to find the bestest one. I can finish off the tank of premix anyways 🙂 …
                                          Just gonna replace the rear shock while the swingarm bolt is out. It doesn’t feel broken but it was crusty 30,000 miles ago. So, yeah! There is that…
