  3. Welcome New Owners!
  4. Hello all
Hello all
58 Posts 5 Posters 25.1k Views
  • M mcludd
    So got about as far as I can with the 250 til I get some stuff back from paint so I will have to turn my attention to the ginger stepchild again tomorrow, anyone got a pre 2004 wiring diagram they could share so I can look at how (if at all ) possible it is to fit an earlier CDI
    #48
    @mcludd Here's a 3NC wiring diagram. The DTR used either 3NC or 3MB wiring between 1989 and about 1998; 3MB is almost identical but you can't run a 3NC CDI on a 3MB loom or vice versa.
    I don't know very much about the '99 onwards wiring which incorporates the reed switch etc but the 3NC and 3MB platforms (and the 3DB from the original round slide carb DTR in 1988) are all full power, even on UK bikes which were just supplied without the YPVS servo and the powervalve pinned closed for the 12bhp learner legislation of the day. I'd steer clear of 3DB electrical parts as the '88 bike had a different bore and stroke to '89 onwards DTRs.
    To run 3NC or 3MB electrics, of the top of my head you'd need:
    CDI unit and main loom
    Stator and flywheel (part numbers are different between 3NC and 3MB)
    Non-DTRe crankshaft if your bike has electric start
    Regulator/rectifier
    3-wire YPVS servo (the 3-wire servo has its own on-board computer and so only requires an RPM signal from 3DB/3NC/3MB CDI units)
    Pattern 6-wire ignition switch
    Left handlebar switch cluster
    Clocks for temp gauge wiring
    Twistgrip (the type with integral kill switch)
    Poss. sidestand switch
    These electrical platforms are a good deal simpler than some of the later bikes and as far as I'm aware the left crankcase has all the correct mounting holes for the non-DTRe stator even on electric start bikes so if you can get hold of all the above parts it could be the easiest way around this. Also if you look around, back in the day there was such a thing as a 3MB DTRe which would be the best electrical platform to go for IMO if you wanted to do this. At one time I owned three French import DTRs; '93 and '98 3NCs and a '98 3MB. All full power (10k rpm +) but the 3MB had noticeably more power than the other two despite having over 65000km on the clock (the 3NC and 3MB have different ignition advance curves).
    The KTM LC2 125 had a DTR engine and ran the 3MB electrical platform so have a look on eBay international for a CDI and servo off one of those, German and Austrian breakers are full of them.
    Anyone can see anything I've left out please feel free to add to this!
    • M
      M
      mcludd
      Thanks for that Hotshot, haven't had chance to act on any of it today - hopefully will get chance over the weekend
        Regulator/rectifier
        It’s all bloody expensive, if you can even find it. Fleabay 3 wires are at about £180 last I looked. Also looms are from there upwards!🙂
        • HOTSHOT IIIH
          #51
          @mcludd No worries bud 🙂
          @SpookDog Yes, all a bit pricey these days and finding a non-butchered 3NC or 3MB loom is the biggest challenge. Saying that Zeeltronic sell all the correct connectors so with a decent crimping tool you could probably make your own for roughly the same cost as buying a used one.
            #52
            I looked at connectors in ‘Bikers Toolbox’
            They aren’t Yamaha OEM, or anything. I like them because they’re waterproof! Good price as well, I think it worked out about 50-60£ for the connectors and the crimping tool, don’t quote me tho! It was a while ago 🙂
            They sell all the wire colours in various gauges, as well as the wrap and sleeve stuff to do a proper job…
            Making a loom is on my to-do list! Summer job for me though. My ‘work bench’ keeps getting flooded at the moment 🫤
            • M
              M
              mcludd
              wrote on last edited by mcludd
              #53
              Wow making a loom has never been on my to do list I bloody hate electrics give me nice mechanical carnage anyday
              So as far as the deet from hell goes, I refitted the rotor plugged all the connectors back in and fired it up - multimeter across the battery 11.8v -BUGGER!!!!!
              Unplugged the rectifier and checked the phase wires - out put on 2, 3rd one still dead stator is knackered despite looking good - I did a continuity check on all three phase wires and have continuity all the way up to the rectifier multi plug suddenly the buying a 12 segment stator rotor and a taper shim is not so mad expensive any more although the temptation to just shelve it until after Christmas and break it is strong, just get my investment back
              • M mcludd
                #54
                @mcludd
                My tzr (1994 4hw) has the same stator and rotor as the RE (blue green wire included )The CDI looks the same as a 3MB one, which is weird cause I thought RE ones were totally different?!
                Point is it might be easier and cheaper to get a tzr stator set. The belgarda might be the same as well…
                • M
                  M
                  mcludd
                  So I had another look at the old girl today and decided I just dont have the time (or enthusiasm really) so I am going to sell it as a complete lump that is an ongoing project if anyone on here is interested you are welcome to have it otherwise I shall list it on evilbay in a week or so
                  • M
                    M
                    mcludd
                    ![alt text](https://i.imgur.com/WPpBSwb.jpg!alt text)
                    • M
                      M
                      mcludd
                      Forgot to mention I paid 1500 and it owes me another 100 in fuel and parts so that what I am looking foralt text
                        Looks pretty tidy
