  4. Gear indicator
Gear indicator
7 Posts 3 Posters 1.5k Views
  • VcelickaV
    VcelickaV
    Vcelicka
    Hi guys, i was wondering if i could get gear indicator on my dt? Does anyone have one or some info on them?
    • VcelickaV Vcelicka
      @Vcelicka
      No, you would need a sensor built into the gear selector barrel, or rod/forks. Like the neutral switch but more. Then you would need an electronic control unit to count the gears and know when you are shifting up or down. Then a display that would fit in with the rest of the ‘dash’…
      You can get air conditioning though! 😜 …
      VcelickaV 1 Reply Last reply
        @Vcelicka
        VcelickaV
        VcelickaV
        Vcelicka
        😂 ok thanks for the reply
          Why couldn't you just use one of these?
          https://www.healtech-electronics.com/products/gipro/gpxt/
            My bad, I didn’t know such things existed…
              Uses a tachosensor/speedsensor and clutch.
              Looks snakeoil to me, but always comes up on my eBay feed for Aprilia RS/Cagiva
                Yeah, I just skimmed through it. I wouldn’t touch it with a shitty stick! 😜
                I’m embarrassed to admit that I sometimes forget what gear I’m in, not often! But trying to pull away from the traffic lights in 3rd is not a good look 😒 …
                It always seems to end up the time it won’t go back down into first, I end up rocking the fuxor backwards and forwards to try and get it to snick into gear! 😐
