  4. engine piston check
engine piston check
73 Posts 6 Posters 19.5k Views 1 Watching
  • E erion1
    @HOTSHOT-III i found a piston that i can get my hands on easy
    its called TKRJ they seem to be made in jappan but it lloks to be cheap so not sure if its very good
    #27
    @erion1
    I think it’s caused by an Ill fitting piston ‘slapping’ around. It enlarges the hole where the pin is sitting, but creates a lip at the edges. That’s been my experience anyways 🙂 …
    Get a small flathead screwdriver and scrape around the hole where the clip sits. Or use wet and dry sandpaper. It’s not like you’re gonna use the piston again!
    I kinda remember Meteor pistons from my past Lambretta and Vespa days. They were good I think…
    WHERE THE FUX YOU LIVE BUD?!
    Italy?…
    E 1 Reply Last reply
      @erion1
      Italy?…
      E Offline
      E Offline
      erion1
      @SpookDog no i live in kosovo but there are shops that have dt parts so it takes 1-2 days to get a piston, but if i want to order from mitaka or somewhere else it could take up to months, thats why im trying to see if any of u used them or have any experiences with meteor or anything as i have easy acces to them
        @erion1 Whereabouts in the world are you based, and what year is your bike?
        If most DT owners near you are happy with Meteor pistons and you can get them easily I'd go with that.
        E Offline
        E Offline
        erion1
        @HOTSHOT-III not sure about the year its a 4bl model 3mb head and 3mb00 cylinder
        • E erion1
          @erion1 You can find out the year of the bike using Yamaha France Parts Lookup as long as the frame has a VIN Number. They seem to have information on any Yamaha product sold in Europe, I've looked up UK bikes on there before:
          https://www.yamaha-motor.eu/fr/fr/service-support/parts-catalogue/
          • E erion1
            #31
            @erion1
            Fux! I don’t know what to recommend. I forget sometimes how spoilt we are ‘in the west’. I’d go with the meteor piston if I was you. I wouldn’t go back to the same place that did your last rebore though, if I could find somewhere else. Get them to measure the bore, then supply the piston that fits the rebore that they do. There should be no noticeable movement in the barrel…
            If you just want to get mobile again desperately, get a decent NEW head and base gasket. Lap the top of the barrel and head with wet and dry sandpaper on a sheet of plate glass…
            I’ve done worse, just don’t cane the beast…
            Wish I could help you more…
              E Offline
              E Offline
              erion1
              @HOTSHOT-III i don have a vin it only has a fin someone told me it would be easy with a vin
                @erion1
                E Offline
                E Offline
                erion1
                @SpookDog it was good when i got it at firs as long as i remember, as for the rebore i got a oversize piston first then sent them together for him to make them fit and the oversize was enough to remove all the scratches, i think that it is movin a slight bit bc of the worn out rings and that it made contact with the cylinder only on those 2 sides and the rings weared ore on those 2 sides and not it taps, hope you understand what i mean
                  @erion1
                  E Offline
                  E Offline
                  erion1
                  • E Offline
                    E Offline
                    erion1
                    hey @SpookDog i was wondering if what happened could cause my crank bearing go bad as someone told me that, is there any way i can check that, i was thinkit that the water that got in caused corrosion on the bearing or something, i just don't want my engine to go boom haha
                    • E erion1
                      #36
                      @erion1
                      E 2 Replies Last reply
                        @erion1
                        E Offline
                        E Offline
                        erion1
                          @erion1
                          E Offline
                          E Offline
                          erion1
                          • E erion1
                            @erion1
                              @erion1
                              E Offline
                              E Offline
                              erion1
                              Thanks for the info!
                                @erion1
                                E Offline
                                E Offline
                                erion1
                                • E erion1
                                  @erion1
                                  • MadGyverM Offline
                                    MadGyverM Offline
                                      @erion1
                                      E Offline
                                      E Offline
                                      erion1
                                      • MadGyverM MadGyver
                                        E Offline
                                        E Offline
                                        erion1
                                        #45
                                        @MadGyver on the front brake hose it is repeated many times it writes DOT NCRN 12/91 1/8 HL im guessing that 12/91 refers to december 1991 maybe ?
                                        • E erion1
                                          @erion1
                                          So it’s pre- 96 I think…
