  4. engine piston check
engine piston check
73 Posts 6 Posters 23.2k Views 1 Watching
    @erion1
    E
    E
    erion1
      @erion1
      E
      E
      erion1
      • E erion1
        @erion1
        E 2 Replies Last reply
          @erion1
          E
          E
          erion1
          Thanks for the info!
            @erion1
            E
            E
            erion1
            • E erion1
              @erion1
              E 1 Reply Last reply
              • MadGyverM
                MadGyverM
                  @erion1
                  E
                  E
                  erion1
                  • MadGyverM MadGyver
                    E
                    E
                    erion1
                    #45
                    @MadGyver on the front brake hose it is repeated many times it writes DOT NCRN 12/91 1/8 HL im guessing that 12/91 refers to december 1991 maybe ?
                    • E erion1
                      @erion1
                      So it’s pre- 96 I think…
                        @erion1
                        E
                        E
                        erion1
                        @SpookDog yeah its a 3wire
                          @erion1
                          E
                          E
                          erion1
                          @SpookDog i got a top end athena gasket kit but since i have to rebore to 57mm bore will it be a problem ?
                          • E erion1
                            #49
                            @erion1
                            No, I have a 58 I use (about 140cc)
                            You do have to check it doesn’t touch the power valve when it gets to a certain size…
                              @erion1
                              E
                              E
                              erion1
                              @SpookDog yeah i know about power valve, i was just thinking would the top end gasket be smaller than the barrel but it should be fine
                              • E erion1
                                @erion1
                                It will be…
                                  @erion1
                                  It will be…
                                  E
                                  E
                                  erion1
                                  @SpookDog yo one last thing i made a video today of kicking the bike over just so you can hear the bike make that friction noise to know if the crank is good, idk maybe just my stress is making me hear it or idk here is the vid https://imgur.com/gallery/HRIy3mb
                                  • E erion1
                                    @erion1
                                    Can’t hear anything over the exhaust! You’ll have to do it turning the stator by hand…
                                      @erion1
                                      E
                                      E
                                      erion1
                                      @SpookDog no i mean the noise that it makes the first 3times that i kick it or maybe its just the normal sound the bike makes when turned over, as for when its runing it doesn't make any noise
                                      • MadGyverM
                                        MadGyverM
                                        @erion1 Have you done a compression test,if something is wrong with the piston or piston rings it should show low compression.
                                        • E erion1
                                          @erion1
                                          I can’t tell bud. Really need to check it without the barrel and piston on it…
