  3. Carburetor
  4. Mystery 35mm inlet
Mystery 35mm inlet
3 Posts 2 Posters 253 Views
  • D
    dan28
    My engine is running a dellortto phbh 28mm carb
    External diameter of carb is 35mm
    The inlet is split near boost bottle
    I ve tries two of other inlets but the internal diameter of the standard inlet is only 32mm
    So my question is what bike is the 35 mm inlet off its the same angle as standard dtr but slightly larger
    • D
      dan28
      bloke on ebay reckons i need a 4DL inlet
        No, the 4DL would have a straight inlet. These don't fit the DTR as thr carb then fouls the shock absorber.
