  4. 170cc Athena Kit wont rev Past 9500RPM
5 Posts 3 Posters 323 Views
  • vtrtomukV
    vtrtomukV
    vtrtomuk
    wrote on last edited by vtrtomuk
    HI Chaps,
    Advice on my predicement please,
    Built a 2003 DT125R last year, with an athena 170cc kit and Full athena exhaust.. life gets in the way and its only this year iv got it out and ran it in, this is a full nut and bolt rebuild, new crank and internals etc..
    specs 2003 DT125R 3RM with a 3RM-20 CDI, Athena 170cc Kit Full athena Exhaust, standard 28MM Carby with 290 Main and 25 Pilot. Inlet reeds are carbon fibre Yambits Jobby.
    under load or with no load it will not rev past 9500rpm like its hitting a rpm govener like a chainsaw....
    iv upjetted and down jetted 270,280,290,300,310,320,330,340 all the same blocked off powerjet and with powerjet etc...
    powervalve is visually aligned up the exhaust port and functioning, but have all so tryed pinning it open, visually confirmed. same thing....
    The Baiscs, new plug, new ht lead,coil and cap, jets as above, snorkle in snorkle off, powervalve pinned and with YPVS. Reed switch behind clocks is out and tucked away out the housing.
    my only other thought is to reduce the plug Gap, but seeing if anyone else has seen this or had exprence with the 170 kit
    any advice aprecated, Cheers
    Current Projects - 2003 DTR
    Have put 12 DTRs back on the road since 2010
    Owner of 4 bikes - Honda VTR1000F 1998 - Honda CBR 600 F3 1998 - Sinnis Apachie 125 2015 - Yamaha DT 125R 2003
      Hi there,
      You're literally describing the characteristics of the big bore engine. It's not going to rev like the OEM setup, a big bore kit will drop over revs and this sounds like it's in the right ball park figure.
      I'm not saying 9500 is the limit, but this is definitely past its peak power and I wouldn't expect any power gains past here.
      The next step for retaining revvibility will involve more drastic tuning.
      • Zeeltronic CDI Ignition System
        • Allows you to have a fully derestricted ignition system
        • Customise powervalve for the Athena kit
        • Squeeze out a few more RPMs
      • Cylinder porting
        • Greater volumetric airflow through the cylinder
        • Allowing it to breathe easier
      • Transfer window porting
        • The transfer windows most likely need porting due to the larger bore
        • Gasket match the cylinder to the cases
      • Porting the cylinder base removing the obstruction to airflow from the reedvalve
        • Air flow is greatly disturbed by the cylinder spigot protruding into the intake
      • Fit VForce4 Reed Block from Blaster
        • Proven to increase mid-range and overrev performance
        • Boyseen dual stage reeds can also help but seeing as your requirement is literally at the top end of the powercurve then you don't want dual stage
      Just bear in mind, you're now demanding a lot more from the engine than stock and seeing as you're seeking peak power you're going to want supporting mods.
      • Uprated clutch springs to avoid clutch slipping
      • Forged connect rod to resist rod stretch/fatigue
      • Forged light weight piston to withstand the demands
      • vtrtomukV
        vtrtomukV
        vtrtomuk
        Thanks for the detailed Calum,
        i must say i was expecting more from this kit, the midrange is a improvement and is quite fun, my expectations on it being rev happy were obvously missplaced.
        really annoying that Athena Dont provide a base jetting range to start, jetting should be done per bike and mods etc, but a rich basline would be nice
        info i got was from here, youtube and https://www.rrd-preparation.com/en/kit-high-engine-motorcycle-125cc-2-times/671-kit-170-cc-athena-racing-for-motor-125-derbi-gpr-yamaha-tdr-dt-tzr-2-time.html
        if anyone stumbles apon this thread some keep the pilot the same but most go up a jet size.to 25 and the main is recomended to be between a 270-290 go 290 if your running in as a newbuild.
        on that note have noticed my silencer packing is a bit oily probably from running a 27.5 and 320 main so ill get that repacked could be chokeing out.
        the ignition system will be a future investment, when funds allow
        • R
          R
          Rallyfinnen
          Some comments:
          The Athena exhaust has only a 19mm stinger, I replaced that with 22mm (ID) stinger, and it improved a bit in the mid to high revs. Also helps keep temperatures down. The silences also has a 'restriction' in the perforated pipe, so it would be good to replace that too (even if I didn't)
          I found raising the cylinder also helps a bit. I found 1,5mm to be a bit too much, 0,5-1mm seems to work. You also need to adjust the head when raising it. I cut my own 'bath tub' chamber with abt 11:1 geometric CR, which seems to be a good compromise to avoid deto with pump gas. At the same time I changed the shape of the piston crown to a 'normal' shape, not the Athena compromise so they could use the same head as the 125 kit.. even the power valve seems to be the same, radius is not matching the 65mm bore..
          I definitely recommend Zeel, it will give you the possibility to tune ignition to get some more over-rev, tune ypvs to the pipe etc.
          Seems to be the transfers that limit the high rev power on the cylinder. Raising the cylinder improves this, because the transfers are far from fully open at BDC. However raising the cylinder also raises the exhaust to extreme durations (approaching 200deg when you start raising the cylinder), and that is not good. As is, the exhaust blowdown STA seems to have margin for more power, but the transfers don't flow enough to support it. So if you are going for porting, I would recommend starting with widening and raising the transfer port windows. I don't think there is much to gain from matching in the crank case etc, it might make you feel better but rarely has any real results unless it's really bad.
          • vtrtomukV vtrtomuk
            @vtrtomuk Yeah, just have to enjoy it for what it is sadly.
            I have had mine ported and got lots of supporting mods to boot. It goes alright, but my Aprilia decimates it completely. Still nice bike to have and you can get some improvements out of it.
