Help needed
How do you torque the barrel bolts as the power valve is in the way and I can't put a socket on
I would suggest the same as Calum, they probably don't have a torque setting, if they're the bolts/bolt that I think you're on about!
The ones I'm talking about are the ones that attach the barrel to the engine casing and will a spanner be okay yeah
@vtrn_raptor Yeah spanner will be fine.
Be sure to tighten in sequence as to not to distort the aluminium
Hi callum, you based in gloucester? Was wondering if you could help me as wanting to mount rs125 front brake on my DT
Thank you & merry chrismas
