  3. Brakes
  4. Help needed
Help needed
6 Posts 4 Posters 1.8k Views
  • V Offline
    V Offline
    vtrn_raptor
    How do you torque the barrel bolts as the power valve is in the way and I can't put a socket on
      Yeah it's pretty shit, just have to make do with a spanner a d FT
      • GoProKid95G Offline
        GoProKid95G Offline
        GoProKid95
        I would suggest the same as Calum, they probably don't have a torque setting, if they're the bolts/bolt that I think you're on about!
        GoProKid95
        2006 DT125RE - SM Conversion
        • V Offline
          V Offline
          vtrn_raptor
          The ones I'm talking about are the ones that attach the barrel to the engine casing and will a spanner be okay yeah
          • V vtrn_raptor
            @vtrn_raptor Yeah spanner will be fine.
            Be sure to tighten in sequence as to not to distort the aluminium
            • U Offline
              U Offline
              UKBikeLife
              Hi callum, you based in gloucester? Was wondering if you could help me as wanting to mount rs125 front brake on my DT
              Thank you & merry chrismas
