Gearbox bearing removal methods / tools?
Engine
7
Posts
3
Posters
3.2k
Views
Watching
I have bought a couple of different tools from eBay for removing bearings but they were all useless/broken/came with no instructions so I couldn't work out how they actually removed the bearings. Crank shaft bearings usually aren't an issue. It's the silly gearbox bearings that are recessed in a closed hole. Any recommendations tools wise? Thanks.
Yes I ended up giving my 250's cases to my local mechanic whilst he was fitting the new bits to my crankshaft. But with the cases, I imagine if there were any oil seals leftover in them, they would melt in the oven?! That's the only issue and reason I was searching for tools, would be nice not to have to remove all the seals to replace one bad bearing.
