  4. lights diming when brake aplied
26 Posts 4 Posters 9.8k Views
  • britshgigoloB
    britshgigoloB
    britshgigolo
    no all standard just uprated the headlight bulb to a 60w as was not very good as it was down the dark lanes
      When riding, the generator should output sufficient power not to dim lights, at tick over on the R yes can have an effect. Not as powerful as the X and RE.
      If it's happening whilst riding then I will say genny isn't working, check a voltmeter over the batter terminals on idle. Should display 14.2v ish. And what's it with the engine off. Should be 12V. Could also be rectifier. Measure the impedance of the rectifier.
      • britshgigoloB
        britshgigoloB
        britshgigolo
        ok ty calum not been feeling good today so not had chance to check anything but as soon as i got some figures will let you know
        • GoProKid95G
          GoProKid95G
          GoProKid95
          Best bet is to dig out your multimetre, start the bike and check to see that everything is doing what it is supposed todo. Begin with the battery and just eliminate everything until you've got your answer. The chances are that the bulb you've got installed is so massive its drawing a huge amount of current, hence the dimming of the other light! 🙂
          GoProKid95
          2006 DT125RE - SM Conversion
          • britshgigoloB
            britshgigoloB
            britshgigolo
            ty goprokids but its the headlight that is dimming when brakes are aplied and all other bulbs are standard still not been well enough to have a look hoping i will feel beter tomorow but will keep you all up to date how i get on
            • britshgigoloB
              britshgigoloB
              britshgigolo
              Right tested battery this morning after been sitting for two days and got 11.96 and with engine running got 14.58
                So the generator works. Whats the voltage when the brakes applied.
                Sounds like there is some excessive load on the genny when the brakes are applied. This could be due to some resistive load. Best check the headlamp connections.
                • britshgigoloB
                  britshgigoloB
                  britshgigolo
                  right had some spare time today and checked all conection and cleaned all conections but still have the same problem but have noticed the higher the revs the worst the problem is so at full brightness high revs the bulb dips more tryed standard bulb back in and it sill doing this not sure what to check now so any help would be good even ran another earth but this still did not help
                  • britshgigoloB britshgigolo
                    @britshgigolo Check the rectifier.
                    • britshgigoloB
                      britshgigoloB
                      britshgigolo
                      @Calum ty calum for the quickresponce as always is there a way to test them or is it just get a new one got multi meter
                        @britshgigolo Check the impedance across it.
                        In theory it should just be a bunch of diodes so continuity should give an idea.
                        • britshgigoloB
                          britshgigoloB
                          britshgigolo
                          @Calum hi mate been a hectic week so have not had any time to check the rectifier so ordered a new one and new battery as it just quicker to replace them have been offered another stator but not sure what one mine has as when looking up seem to be diffrent types i assume for diffrent years would you know if the 2001 dtr is the one with the 3 pulse coils as thats the type i can get hold of and thinking to get it just incase as i know you can replace the 3 pulse coils separately so thinking good as spares incase it is at fault i would check whats fitted but waiting on the flywheel puller to turn up to as did not have one
                          • britshgigoloB
                            britshgigoloB
                            britshgigolo
                            wrote on last edited by britshgigolo
                            Right finally got time to test the stator and I'm getting higher reading then what the Haynes manual says I think I'm testing it right pics to show
                            So I'm getting 813 from the stator and 274 from the pick up coil so from the Haynes it says pulser coil 280 to 420 and source coil 192 to 288 does this sound right any help would be great pics are to show how testing0_1486221475840_IMG_2222.JPG 0_1486221489437_IMG_2224.JPG 0_1486221496052_IMG_2223.JPG 0_1486221502564_IMG_2226.JPG 0_1486221508926_IMG_2225.JPG
                            • britshgigoloB
                              britshgigoloB
                              britshgigolo
                              can some one tell me if i have tested this right please have got another stator coming tomorrow as im sure its giving wrong reading acording to the haynes
                              • britshgigoloB
                                britshgigoloB
                                britshgigolo
                                well looks like i been a dick as did not read the amendments at the back of the haynes for the newer type stator so turns out that mine was ok all along well got a spare now for a rainy day
                                  @britshgigolo Nice one bud, thanks for updating us. Makes it useful to anyone else having similar problems.
                                  Continuing reporting back to us as you find out more information.
                                  Again I suggest applying the brakes and reading the voltage drop across the battery.
                                  You can get SMD bulbs to go in for the brake and side lights. This may help reduce the load from like 15w bulb to 1w. May help.
                                  I run SMD lights.
                                  britshgigoloB 1 Reply Last reply
                                  • britshgigoloB
                                    britshgigoloB
                                    britshgigolo
                                    with the new rectifier and battery it seems better but not been out in the dark yet but with it running a 6000 revs and looking at the front light while brake is aplied could not see it change but is was day light so dont mean to much till i take it out at night but hoping it was one of them and still need to test old rectifier too on the bench
                                    • britshgigoloB
                                      britshgigoloB
                                      britshgigolo
                                      @Calum and i was thinking about running leds for all the lights but not had time to look up whats best suited
                                        I run SMD lights.
                                        britshgigoloB
                                        britshgigoloB
                                        britshgigolo
                                        @Calum said in lights diming when brake aplied:
                                        I run SMD lights.
                                        do you need to run resistors when running led bulbs
                                          @britshgigolo You know it could simply be the battery is dying. Once the brakes applied the revs will be dropping and then its relying on the battery, which too might be dyig and thus the lights dim.
