  4. lights diming when brake aplied
26 Posts 4 Posters 9.8k Views
  • britshgigoloB britshgigolo
    @Calum ty calum for the quickresponce as always is there a way to test them or is it just get a new one got multi meter
    @britshgigolo Check the impedance across it.
    In theory it should just be a bunch of diodes so continuity should give an idea.
    • britshgigoloB
      britshgigoloB
      britshgigolo
      @Calum hi mate been a hectic week so have not had any time to check the rectifier so ordered a new one and new battery as it just quicker to replace them have been offered another stator but not sure what one mine has as when looking up seem to be diffrent types i assume for diffrent years would you know if the 2001 dtr is the one with the 3 pulse coils as thats the type i can get hold of and thinking to get it just incase as i know you can replace the 3 pulse coils separately so thinking good as spares incase it is at fault i would check whats fitted but waiting on the flywheel puller to turn up to as did not have one
      • britshgigoloB
        britshgigoloB
        britshgigolo
        wrote on last edited by britshgigolo
        Right finally got time to test the stator and I'm getting higher reading then what the Haynes manual says I think I'm testing it right pics to show
        So I'm getting 813 from the stator and 274 from the pick up coil so from the Haynes it says pulser coil 280 to 420 and source coil 192 to 288 does this sound right any help would be great pics are to show how testing0_1486221475840_IMG_2222.JPG 0_1486221489437_IMG_2224.JPG 0_1486221496052_IMG_2223.JPG 0_1486221502564_IMG_2226.JPG 0_1486221508926_IMG_2225.JPG
        • britshgigoloB
          britshgigoloB
          britshgigolo
          can some one tell me if i have tested this right please have got another stator coming tomorrow as im sure its giving wrong reading acording to the haynes
          • britshgigoloB
            britshgigoloB
            britshgigolo
            well looks like i been a dick as did not read the amendments at the back of the haynes for the newer type stator so turns out that mine was ok all along well got a spare now for a rainy day
              @britshgigolo Nice one bud, thanks for updating us. Makes it useful to anyone else having similar problems.
              Continuing reporting back to us as you find out more information.
              Again I suggest applying the brakes and reading the voltage drop across the battery.
              You can get SMD bulbs to go in for the brake and side lights. This may help reduce the load from like 15w bulb to 1w. May help.
              I run SMD lights.
              britshgigoloB 1 Reply Last reply
              • britshgigoloB
                britshgigoloB
                britshgigolo
                with the new rectifier and battery it seems better but not been out in the dark yet but with it running a 6000 revs and looking at the front light while brake is aplied could not see it change but is was day light so dont mean to much till i take it out at night but hoping it was one of them and still need to test old rectifier too on the bench
                • britshgigoloB
                  britshgigoloB
                  britshgigolo
                  @Calum and i was thinking about running leds for all the lights but not had time to look up whats best suited
                    I run SMD lights.
                    britshgigoloB
                    britshgigoloB
                    britshgigolo
                    @Calum said in lights diming when brake aplied:
                    I run SMD lights.
                    do you need to run resistors when running led bulbs
                      @britshgigolo You know it could simply be the battery is dying. Once the brakes applied the revs will be dropping and then its relying on the battery, which too might be dyig and thus the lights dim.
                        I run SMD lights.
                        @britshgigolo No SMD. Surface Mounted Diodes. They already have the resistors on them. So they should just work out the box.
                          britshgigoloB
                          britshgigoloB
                          britshgigolo
                          @Calum ty mate and the old battery was holding charge but replaced to make sure
