  4. Clutch
Clutch
67 Posts 7 Posters 23.0k Views 2 Watching
  • RickyR Ricky
    I put it all back in and the revs still die down when I pull the clutch in and when I put it in natural the engine vibrates where the clutch is
    @Ricky How bad is the vibration??
    As said the clutch is weighted and needs to be balanced properly.
    If the clutch is REALLY bad, then sounds like it hasn't been timed correctly with the balancer shaft.
    Has the engine been rebuilt?
    Remember, it is a two stroke, expect vibrations. Again it comes down to how bad.
    Could be lose engine mounts...
    RickyR 1 Reply Last reply
      RickyR Offline
      RickyR Offline
      Ricky
      @Calum it only happens when I put it in natural and let my clutch out as soon as I pull my clutch in it stops but then the revs die down its only started doing this since I put the new clutch in
      DT 125X
      • RickyR Ricky
        @Ricky And again to confirm, you definitely balanced the clutch properly as I described?
        The clutch springs the old ones? Are they within tolerance? Are they torqued appropriately.
          RickyR Offline
          RickyR Offline
          Ricky
          @Calum yeah I spaced the notches out on the metal plates evenly the springs are new this is the clutch i got http://m.ebay.co.uk/itm/EBC-DRC-COMPLETE-CLUTCH-KIT-FITS-YAMAHA-DT-125-X-2005-2006-/131742599793?nav=SEARCH
          DT 125X
          • RickyR Ricky
            @Ricky Don't really know what to suggest then.
            Could be worn primary drive bearings and pulling the clutch out exacerbates things.
            How many miles has the engine done, and has it ever been rebuilt?
              RickyR Offline
              RickyR Offline
              Ricky
              @Calum it's done 20k not sure when it was rebuilt
              DT 125X
              • RickyR Ricky
                @Ricky Well if it's original internals then it could be knocking, which will mean it'll need a rebuild.
                if it's been rebuilt then it could be that it hasn't been assembled properly, and the engine hasn't been timed up properly. But the vibration when the engine isn't timed up is really bad!
                  RickyR Offline
                  RickyR Offline
                  Ricky
                  @Calum it's not that bad I don't think haha but it only started since i put the new clutch in
                  DT 125X
                  • MightymanM Offline
                    MightymanM Offline
                    2 stroke KTMs are renound for an unusual sound if you aren't holding the clutch in but what you are describing seems like more than just this..
                    • MightymanM Mightyman
                      RickyR Offline
                      RickyR Offline
                      Ricky
                      @Mightyman this never use to do till I changed the clutch
                      DT 125X
                      • RickyR Ricky
                        @Ricky Probably just paranoai. You definitely got enough oil.in there yeah.
                        • DartyD Offline
                          DartyD Offline
                          Go back in and check the torque on the nuts, is it noisy? like a continuous ticking sound? Clutch plates are slipping if the revs are dying, Re-adjust the clutch action on the clutch itself.
                          Mine did this once, but vibration suggests bearing, or loose plates, which seems unlikely.
                          RickyR 2 Replies Last reply
                            RickyR Offline
                            RickyR Offline
                            Ricky
                            @Calum haha something is different and yeah 750ml
                            DT 125X
                              RickyR Offline
                              RickyR Offline
                              Ricky
                              @Darty it's more like a thudding noise than a tapping
                              DT 125X
                                RickyR Offline
                                RickyR Offline
                                Ricky
                                @Darty the inner basket spins when I tighten the springs up I've got them tight
                                DT 125X
                                • RickyR Offline
                                  RickyR Offline
                                  Ricky
                                  wrote on last edited by Ricky
                                  What's the best way to put the metal plates in sharp side facing the engine or the smothered side I've been told it doesn't matter as long as there all the same way
                                  DT 125X
                                    MightymanM Offline
                                    Could be worth posting a video so we can hear the noise. Might be easier than describing it 😂
                                      RickyR Offline
                                      RickyR Offline
                                      Ricky
                                      @Mightyman good idea haha I'll do it later
                                      DT 125X
                                      • RickyR Offline
                                        RickyR Offline
                                        Ricky
                                        #23
                                        A video as promised please ignore the tapping lol
                                        https://youtu.be/BdgV44NU6D8
                                        DT 125X
                                          So what's the tapping?
                                          The fact the idle goes down with the clutch in doesn't really bother me. I see that a lot, usually the thrust bearings going on the clutch, however we don't have those.
                                          What we do have is a primary drive bearing, which if it's on its way out, will vibrate and probably cause this sort of issue.
                                          With that sort of mileage on a two stroke, and an uncertainty of the engines age, I'd be stripping it down for a rebuild...
                                          I don't think we're going to diagnose it really.
                                          If it isn't what I've been suggesting then I really think it might just be an engine rebuild jobby, or paranoia.
                                          If it was really bad then you would know. Again it all comes back to how much vibration. If it's a lot, then it's for a reason. But two strokes rattle a lot anyway so it's really hard to tell.
