  4. Clutch
Clutch
67 Posts 7 Posters 22.2k Views 2 Watching
  • RickyR Offline
    RickyR Offline
    Ricky
    wrote on last edited by Ricky
    Hi guys I'm replacing my clutch and I've had to buy a new washer that goes in between 1 of the plates I'm unsure where it goes and 1 of my plates is smaller than the others and don't know where that goes either I'm hoping someone can help thanks I've uploaded a pic of the clutch 0_1485103503757_20170117_160845.jpg
    DT 125X
    • RickyR Ricky
      @Ricky Check my tutorial in the Kickstart conversion bud.
      The plates are also weighted and need to be balanced.
      I've described this process there.
      Check it out!
      • RickyR Offline
        RickyR Offline
        Ricky
        Cheers mate ill have a look now
        DT 125X
        • RickyR Offline
          RickyR Offline
          Ricky
          I put it all back in and the revs still die down when I pull the clutch in and when I put it in natural the engine vibrates where the clutch is
          DT 125X
          • RickyR Ricky
            @Ricky How bad is the vibration??
            As said the clutch is weighted and needs to be balanced properly.
            If the clutch is REALLY bad, then sounds like it hasn't been timed correctly with the balancer shaft.
            Has the engine been rebuilt?
            Remember, it is a two stroke, expect vibrations. Again it comes down to how bad.
            Could be lose engine mounts...
            RickyR 1 Reply Last reply
              RickyR Offline
              RickyR Offline
              Ricky
              @Calum it only happens when I put it in natural and let my clutch out as soon as I pull my clutch in it stops but then the revs die down its only started doing this since I put the new clutch in
              DT 125X
              • RickyR Ricky
                @Ricky And again to confirm, you definitely balanced the clutch properly as I described?
                The clutch springs the old ones? Are they within tolerance? Are they torqued appropriately.
                  RickyR Offline
                  RickyR Offline
                  Ricky
                  @Calum yeah I spaced the notches out on the metal plates evenly the springs are new this is the clutch i got http://m.ebay.co.uk/itm/EBC-DRC-COMPLETE-CLUTCH-KIT-FITS-YAMAHA-DT-125-X-2005-2006-/131742599793?nav=SEARCH
                  DT 125X
                  • RickyR Ricky
                    @Ricky Don't really know what to suggest then.
                    Could be worn primary drive bearings and pulling the clutch out exacerbates things.
                    How many miles has the engine done, and has it ever been rebuilt?
                      RickyR Offline
                      RickyR Offline
                      Ricky
                      @Calum it's done 20k not sure when it was rebuilt
                      DT 125X
                      • RickyR Ricky
                        @Ricky Well if it's original internals then it could be knocking, which will mean it'll need a rebuild.
                        if it's been rebuilt then it could be that it hasn't been assembled properly, and the engine hasn't been timed up properly. But the vibration when the engine isn't timed up is really bad!
                          RickyR Offline
                          RickyR Offline
                          Ricky
                          @Calum it's not that bad I don't think haha but it only started since i put the new clutch in
                          DT 125X
                          • MightymanM Offline
                            MightymanM Offline
                            2 stroke KTMs are renound for an unusual sound if you aren't holding the clutch in but what you are describing seems like more than just this..
                            • MightymanM Mightyman
                              RickyR Offline
                              RickyR Offline
                              Ricky
                              @Mightyman this never use to do till I changed the clutch
                              DT 125X
                              • RickyR Ricky
                                @Ricky Probably just paranoai. You definitely got enough oil.in there yeah.
                                • DartyD Offline
                                  DartyD Offline
                                  Go back in and check the torque on the nuts, is it noisy? like a continuous ticking sound? Clutch plates are slipping if the revs are dying, Re-adjust the clutch action on the clutch itself.
                                  Mine did this once, but vibration suggests bearing, or loose plates, which seems unlikely.
                                  RickyR 2 Replies Last reply
                                    RickyR Offline
                                    RickyR Offline
                                    Ricky
                                    @Calum haha something is different and yeah 750ml
                                    DT 125X
                                      RickyR Offline
                                      RickyR Offline
                                      Ricky
                                      @Darty it's more like a thudding noise than a tapping
                                      DT 125X
                                        RickyR Offline
                                        RickyR Offline
                                        Ricky
                                        @Darty the inner basket spins when I tighten the springs up I've got them tight
                                        DT 125X
                                        • RickyR Offline
                                          RickyR Offline
                                          Ricky
                                          What's the best way to put the metal plates in sharp side facing the engine or the smothered side I've been told it doesn't matter as long as there all the same way
                                          DT 125X
