  3. wheelies
wheelies
30 Posts 7 Posters 9.4k Views 2 Watching
    Your not going to find much extra power, get her jetted nice first,
    Raise the rear the ride height,, and gear it down (bigger sprockets) will help dramatically!
    A 1 Reply Last reply
    • A
      A
      anima
      am i right in thinking that big one expansion chambers are restricted anyway ? i have heard so and i can see a kind of mesh thing near the echaust manifold but in the start of the chamber pipe
      DartyD 1 Reply Last reply
      • britshgigoloB
        britshgigoloB
        britshgigolo
        im running standard sprocket set up as standard as did not want to lose top end as use a roads as well
        • britshgigoloB
          britshgigoloB
          britshgigolo
          i dont know much about exhaust to be fair only everyone says dep are the best buth rust like hell thas why i stayed with the standard pipe and de risticked it
            A
            A
            anima
            @Darty its pretty highly jacked anyway but illl look into a jack up kit
            • A anima
              @anima no idea,
              but BigOne expansion chambers are designed to make more Midrange torque, a proper homologated road pipe,
              If there is a baffle in the expansion chamber, then defo remove it tho,
                @anima no idea,
                A
                A
                anima
                @Darty i will do once i fit my dep then i got the big one as a spare only thing is as has been said the deps rust easily my big one is nearlya year old and still in perfect nick no rust practically no discolouration at all
                • A anima
                  @anima I know, Dep will rust to shit within a year without constant attention,
                  I've had mine 4 years, only managed 7000 miles out of it,
                  But, its the best stamped pipe for it unfortunately,
                  4cm Jack up kit is a good height btw, I've ridden a few DT setups now,
                  • A
                    A
                    anima
                    any reccomendations on where to get a jack up kit from ?
                    • A
                      A
                      andrewj1680
                      Acf 50 solves the problem of the dep exhaust rusting it's pretty expensive around £15 but it works I lagged mine a couple of months back after a clean and it's still the same condition as it was when I first sprayed it, yes it burns off the eccess when you get the bike hot but it's still protects I plan to use it every 3 months and a can seems to go a very long way
                      • A anima
                        @anima I have a used set of dog bones/jack up links, you can have em for £35 posted.
