  3. Carburetor
  4. What carb is this ?
What carb is this ?
14 Posts 4 Posters 2.9k Views 1 Watching
  • rogeringR Offline
    rogeringR Offline
    rogering
    Having troubles with this carb ATM so any info what it's from and will it work properly on my dtr ?
    I am planning on using the larger one but I can't source the insert and pin and lid anywhere
    Any info appreciated 👍
      The one on the left is the mikuni tms28 carb that comes standard on the dt
      • rogeringR Offline
        rogeringR Offline
        rogering
        I know that mate I'm planning on using that one but I haven't got the inserts pin and lid trying to source those parts the,but the small mikuni should that run my bike OK ?? As I'm having troubles with it ATM but I'm going to go through the carb setting guide you have posted
          I would imagine it's going to run seriously rich lol.
          rogeringR 2 Replies Last reply
          • Louis-DT-WRL Offline
            I'm pretty sure that some dts had a different carb than the tm28ss and it was 26mm bore.
            • Louis-DT-WRL Louis-DT-WR
              @Louis-James Really early DT's ran a round slide carb.
                @Calum vmss26 or something, looks similar to the one in the picture
                  D Offline
                  D Offline
                  dtr mkd
                  @Calum the right one is also a DTR carb. older model
                    rogeringR Offline
                    rogeringR Offline
                    rogering
                      rogeringR Offline
                      rogeringR Offline
                      rogering
                      @Calum said in What carb is this ?:
                      That's what's happening this is my problem atm it's running far to rich how do I combat this ?
                      • rogeringR rogering
                        @rogering As I said the other night, I have posted a blog about this I suggest you read it.
                        • rogeringR Offline
                          rogeringR Offline
                          rogering
                          OK thanks mate was meaning to walk through it today but my battery died and ended up finishing other things on the bike, better luck tomorrow eh
                          • rogeringR Offline
                            rogeringR Offline
                            rogering
                            Just to let everyone know the carb in question on the right I've found out its a DT 125 carb 👍
                              Look at this on eBay http://www.ebay.com/itm/262372673935
                              That should be the top of the Mikuni carb
