  4. Yamaha dt125r oil pump
17 Posts 3 Posters 4.5k Views 1 Watching
  • M Offline
    M Offline
    Martinez
    I guys ..my name is hugo martinez i am from.portugal. I have a problem . I buy a dtr 125 year 2000. I think the oil pump send to much oil. I cant find any help on youtube . How i reajust the oil pump to send less oil?.
    • M Martinez
      @Martinez post a pic please as there 2 different systems
      M 2 Replies Last reply
      • M Offline
        M Offline
        Martinez
          M Offline
          M Offline
          Martinez
          @declan i cant put here picture. Is the oil pump for yamaha dt125r year 2000.
            M Offline
            M Offline
            Martinez
            @declan https://youtu.be/WwFUzgr2xnA
            • M Martinez
              @Martinez it's the same as that one in the video? If so there's not much you can do in terms of adjustment from what I know it's supposed to be fixed in place with 2 circlips what setting is yours on when the throttle is rested?
              M CalumC 2 Replies Last reply
                M Offline
                M Offline
                Martinez
                @declan its the same oil pump. The exaust send to much smoke. And drop oil to.
                • M Martinez
                  @Martinez I'm afraid I've used up my usefulness so hold tight and I'm sure one of the more experienced people will help you out
                  M 1 Reply Last reply
                    M Offline
                    M Offline
                    Martinez
                    @declan thanks . For the help .. 👍
                      @declan said in Yamaha dt125r oil pump:
                      Not true.
                      The cable the connects the oil pump to the throttle can be adjusted at the point that it meets the oil pump housing. There is a 90 degree bend on the cable where it meets this housing. The bend is made out of metal and is connected via a hexagonal threaded bar. By adjusting this you will be able to determine how much oil is injected.
                      However if the pump lines up like in my video, then there is only two possibilities.
                      Either the oil pump has gone faulty, in which case adjusting the pump won't achieve anything.
                      Or the crank shaft seals have gone and you are in fact burning gearbox oil.
                      declanD M 4 Replies Last reply
                        Not true.
                        @Calum sorry for my mistake was just going on how my pump is 😐
                          Not true.
                          M Offline
                          M Offline
                          Martinez
                          @Calum i have a picture but i cant put here
                            Not true.
                            M Offline
                            M Offline
                            Martinez
                            @Calum do have email to send you a photo. I think the pump is not ajusted.
                            • declanD Offline
                              Yeah mine aren't working either
                                Picture upload is working fine....
                                  M Offline
                                  M Offline
                                  Martinez
                                  @Calum for me doesnt work. The risc in pump is in the number 2. Is too much.
                                    Not true.
                                    M Offline
                                    M Offline
                                    Martinez
                                    @Calum i cant find the place to reajust
