  4. Dt 125 re 2007
Dt 125 re 2007
23 Posts 4 Posters 6.4k Views
  • britshgigoloB britshgigolo
    mine gets hot on a roads when going flat out it burns the paint off the exhaust from the manifold to just after the bend but it been like that since ive had it change exhaust as thought it may be slightly blocked as was blowing the rubber joint every week but still the same after new exhaust but only does this on A roads flat out aroun town it is fine hope this helps
    R
    R
    reecesloane 2017
    @britshgigolo
    How hot does your silencer get revenge that is to hot to touch after a shot ride
    • britshgigoloB
      britshgigoloB
      britshgigolo
      must admit never felt the silencer but will check when i get to work tomorrow morning but have melted many rubber conectors now have made pipe longer so silencer and exhaust dont have the slight gap and use a silicon hose reducer and have not melted and poped anymore conectors
        Light isn't coming on?
        Right mate Yeah it's fine you are worrying over nothing.
        It's not a crosser the standard pipe is solid and absorbs lots of heat. I remember mine absolutely stank when I rode it home down the motorway.
        But once it was home it was fine. As said that's just normal, the cat will cause the engine to run hot anyway.
        R 1 Reply Last reply
        • R
          R
          reecesloane 2017
          Does the standard pioe have a cat ? Dint k own that I'm gunna do away with that pipe
          buy a dep
            R
            R
            reecesloane 2017
            @Calum light hasn't come on yet
            • R reecesloane 2017
              buy a dep
              @reecesloane-2017 Yeah mate. I got a thread on here about removing it. Don't. It's a royal pain the ass.
              The stock pipe has a huge honeycombe system in it. It stinks when hot lol.
              But it's a quality pipe.
              • R
                R
                reecesloane 2017
                Thanks for the help buddy almost put my mind at rest is it normal to see heat waves from the front pipe
                I was really worried about jetting because the snorkel removed and the boost bottles
                  @reecesloane-2017 Put the snorkel back in, I do have one for sale actually.
                  And the boost bottle, also have the inlet one for sale. I must have the boot one lying about as well!
                  Yeah the pipe is going to get hot because it retains so much heat due to its thickness and material, as such yes you will see heat waves.
                  • R
                    R
                    reecesloane 2017
                    Awesome how much you wanting for the bigger boost bottle the front one and the snorkel mines an 07 btw
                      @reecesloane-2017
                      http://www.ebay.co.uk/itm/262948112886?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
                      http://www.ebay.co.uk/itm/262949644469?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
                      The snorkel is modified so that it will let in more air, but not disrupt the air flow.
                      It may not be what you're after.
                      The boost bottle is in fine condition.
                      For forum members I would do both of them for £15, so long as you don't buy it through eBay lol and I get charged shed loads of fees.
                      Just let me know here and I will take down the eBay ad.
                      • R
                        R
                        reecesloane 2017
                        I'll take the boost bottle
                        Please mate I've found a standard snorkel
                          @reecesloane-2017 Nice, I'll do the boost bottle for £8 if you're happy with that?
                          • R
                            R
                            reecesloane 2017
                            Yeah lovely cheers how do we go about it
                            • britshgigoloB
                              britshgigoloB
                              britshgigolo
                              well after going to work this morning the silencer was to hot to hold onto so yes my exhaust and silincer get hot but only noticed this on a roads
                              • R
                                R
                                reecesloane 2017
                                Thanks for the info after seeing what's inside the stock pipe today I'm not suprised they get hot they have an actual honeycomb cat in side no wonder I'm going to do away with it and get a dep I've give up worrying and just been having fun and the temp light hasn't come on I did 70 on it today with ease and I'm a big lad which was a surprise it stunk after though
