  4. New bike, no clue
New bike, no clue
45 Posts 6 Posters 14.0k Views
  • D dazzagtir
    Thanks for the replies guy.
    Ive just taken the carb to pieces and rebuilt it again with the new rubber gasket in place.
    It all seemed fine when I connected it until I turned the fuel on and the fuel just went straight into the carb and straight back out the over flow.? Litterally poured out as quickly as it was going in.
    Ive since turned it off and on again and its now stopped.... must have been the float sticking.?
    Ive just taken the coil off and used a multimeter to it, ive set the multimeter to 200 ohms and i'm getting a reading of 01.1/01.3.
    HT lead set on 20k ohms is reading 10.70
    Does that sound like a fault coil.?
    Thanks in advance.
    @dazzagtir Sounds like the float valve isn't shutting the fuel off properly bud.
    • D Offline
      D Offline
      dazzagtir
      Regarding the lack of spark, ive just got back from the closest parts store and they tested my coil, lead and cap and said they were all perfectly fine.
      Any idea what else could be causing a lack of spark/?
      I have the CDI in my hand but I do not know how to test it.?
      Thanks for all your help.
      • D Offline
        D Offline
        dazzagtir
        Right.....
        Ive got the bike going..!
        Sounds healthy enough, no fuel leaking anymore either.
        HOWEVER.....
        I just took it out for a ride about 5 miles in total, it doesn't seem to tick over very well, it runs correctly with the choke on but not very well with the choke off.
        (I'm guessin choke on is up and choke off is down?)
        The revs can be controlled using the idle screw on the carb when the choke is on, however if you turn the choke off is revs higher and cant be adjusted with the screw...?? Abit weird.
        When riding along, pull the clutch in the change gear and the revs creep up and you get abit of a (I look like I cant ride a bike moment when you release the clutch because the revs are high)
        Also when stopping the bike the revs creep up and rev high like i'm being impatient.!
        Is this something someone has experienced before and found the answer to.?
        Atm I'm guess the throttle cable may need replacing perhaps.
        Thanks.
        • D Offline
          D Offline
          dazzagtir
          https://youtu.be/ztLEDHhzSto
          • D dazzagtir
            @dazzagtir I was experiencing simmilar things with my freshly rebutilt bike it seemed to be the throttle cable pulling slightly which threw all the other adjustments off check this as I tried hours on end and this sorted it
            • D Offline
              D Offline
              dazzagtir
              Awesome, thanks Declan.
              I will go and try that now. 👍
              • D Offline
                D Offline
                dazzagtir
                She needs a clean but she's now running great.
                Spend some time re routing the throttle cable and adjusting the idle screw with less premix fuel.
                Thanks everyone for your input and help. 👍
                • D dazzagtir
                  @dazzagtir told you bud I spent days on mine because of my aftermarket throttle glad your enjoying it!
                  • D Offline
                    D Offline
                    dazzagtir
                    Cheers Declan.
                    I just need to sort the electrixs out now, the last owner took it upon himself to remove the indictors and hide all the wires somewhere.
                    I don't like the idea of riding it on the road with no indicators as i'm sure the police will not take it lightly.
                    • D dazzagtir
                      Cheers Declan.
                      @dazzagtir It is not a legal requirement for bikes to have indicators. Provided there is no switch, or tape is over the switches, it eill pass an MOT.
                        @Calum yeah a bike can pass mot with no lights or indicators but the the thing is it's either all electrics or none as far as I know
                        • C Offline
                          C Offline
                          castrolsniffer
                          wrote on last edited by castrolsniffer
                          #37
                          Yeah daytime mot, but then u gotta be home by dark 😣
                          • C castrolsniffer
                            @castrolsniffer Uuhh what?
                            No just tape over the indicator buttons.
                            As said don't need indicators on bikes.
                            The other one is that Day Time MOT is no different from a full MOT. Same slip just in the notes it'll say no lights upon inspection. Literally no reason why you couldn't, although probably shouldn't, fit lights to it once it passes. And then don't have to be in at night.
                            • D Offline
                              D Offline
                              dazzagtir
                              Ahhh thats very interesting to know, certainly put my mind to rest knowing I can actually take it out for a ride. I have been avoiding riding it as much as possible.
                              I have ordered some cheap £6 ebay indicators this evening so when they arrive I will fit them.
                              I will however put some tape over my switch tomorrow just incase I do get pulled over.
                              • M Offline
                                M Offline
                                Minia
                                Indicators have never been a requirement, and I certainly don't have them on Enduro/Off-road bikes like the GasGas. Then it just becomes an inconvenience as the electrics add weight.
                                • M Minia
                                  @Minia not only that but the slightest of brushes and they commit suicide 😔
                                  • C Offline
                                    C Offline
                                    castrolsniffer
                                    Nice one guys,you learn something new every day as they say,I've always known it as a daytime mot haha turns out there's no such thing 😂
                                    • C castrolsniffer
                                      @castrolsniffer yep day time mot is just an easy way of saying no lights lol
                                      • D Offline
                                        D Offline
                                        dazzagtir
                                        Ha, I love learning new stuff that will stick in the cranium for ever now. 😂
                                        Thank guys and girls. 😊
                                        • D dazzagtir
                                          @dazzagtir "girls" what ya tryna say lol 😂😂😂
