  3. Welcome New Owners!
  4. Dt125x sm
Dt125x sm
13 Posts 3 Posters 3.3k Views
    @David usually a few on eBay
    David
    @declan I have looked there it just seems 2 b dt125r or dt125 forks just no dt125x
    declanD 2 Replies Last reply
    • D David
      @David I'll have a look for you
      • D David
        @David https://www.bike-parts-yam.com/yamaha-pieces-catalogue-2058-23.html enjoy.
          David
          @declan yeah seen them was hoping 2 not pay as much 2 b honest with ya
            Firstly are they actually damaged, or have you not installed the seals correctly.
            Secondly, you can have your fork stanchion replated if it is pitted, it will be substantially less than the link provided.
              David
              @Calum nope not damaged not bend never been hit I got new seals put in about 2 weeks ago and they started leaking a week after that it was a motorbike shop that did them for me he said it could b a few we nicks on the tube but they were fine before I got new seals done on both forks rite fork is great only left is leaking
              • D David
                @David wasn't aware of that service that @Calum mentioned so I would go with that
                  Personally sounds like the company you got to do it isn't very competent.
                  If they were that pitted they should have told you before completing the work.
                  I would dismantle them myself and examine them. If they are bad you can have them rechromed.
                  Otherwise I would just buy a genuine oil kit (should be quite expensive) then rebuild them using genuine products.
                  Make sure you use Gaitors or seal savers, and you should be good to go.
                  declanD D 2 Replies Last reply
                    @Calum yeah that's true my bike shop won't sell me anything that has to be modified to fit my bike quite annoying sometime but yeah could try another shop maybe
                      David
                      @Calum thanks guys some really gud advice there going 2 take it back 2 the guy that said he fixed it and get him 2 check the seals over again and may b get new tube put on if they r piting that bad but the look spot on 2 me thanks again
                      • D David
                        @David best of luck mate
