  4. DT125R 1994 Running Project
65 Posts 7 Posters 19.1k Views 1 Watching
  • terry.tzT terry.tz
    in need of a muffler and bracket
    @terry-tz yesss glad to hear she's back on the road!
      @terry-tz that exhaust looks like something off the rear end of an old metro lol
      • terry.tzT Offline
        terry.tzT Offline
        terry.tz
        looks good but don't think the DT likes iridium plug cut out on me a few times and been a pain to start so I removed the oring I had holding it more open and it been fine but at full chat ish it has bogged a few times very slight think it could be getting to oily
          @terry-tz wellits deffo running rich throw a new plug in and plug chop it if you really want to find out
          terry.tzT 1 Reply Last reply
            terry.tzT Offline
            terry.tzT Offline
            terry.tz
            @declan tbh im probably just gonna use ES plugs i would like it to be a bit rich got some traveling to do
              @terry-tz I use es plugs they are pretty good only fouled one
                terry.tzT Offline
                terry.tzT Offline
                terry.tz
                @declan I always carry a spare ES anyways just in case
                • terry.tzT Offline
                  terry.tzT Offline
                  terry.tz
                  I no longer think it's the plug seems to be a restriction but sometimes I get 80 and others 70 or anywhere in between il get to the bottom of it
                  • terry.tzT Offline
                    terry.tzT Offline
                    terry.tz
                    I looked at the de restricting stuff online and apart from exhaust and port all is meant to be good but I swear I have a cdi retardation or something at 9-10k ish I not taken much notice will now tho any one know what it could be
                      @terry-tz my bike only revs till around 9 not been able to find the restriction yet
                        terry.tzT Offline
                        terry.tzT Offline
                        terry.tz
                        @declan im not that bothered it goes as fast as am bothered on a dirt bike but it's annoying knowing it's restricted some how and the feeling when it cuts ignition for a second bugs me
                          @terry-tz yeah coming from my usual bikes the dt feels like a monster but would like a longer power curve so I need to get the restriction sorted
                          • terry.tzT Offline
                            terry.tzT Offline
                            terry.tz
                            • terry.tzT Offline
                              terry.tzT Offline
                              terry.tz
                              • terry.tzT Offline
                                terry.tzT Offline
                                terry.tz
                                about time I was more active so let's get things moving new exhaust chain and sprockets first I think as the current exhaust is, to say the least, f!cked and chain seems to be stretching fast been readjusting more than normal
                                  @terry-tz can’t say as I’ve had to adjust my chain due to stretch i done it maybe twice
                                  • terry.tzT Offline
                                    terry.tzT Offline
                                    terry.tz
                                    • terry.tzT Offline
                                      terry.tzT Offline
                                      terry.tz
                                      fitted today love it but it won't a straight fit sounds sweet il be rebuilding the carb in a few days when I have the time as I think it's a bit rammy in there not been running right for a week seems lean at full throttle enough to cut the bike out and now I fitted the pipe need to check how she runs new chain and sprockets going on to same in a few days oh and a tach cable to mine broke a few weeks ago
                                        That's bloody lovely that.
                                        What was the problem fitting it?
                                          terry.tzT Offline
                                          terry.tzT Offline
                                          terry.tz
                                          @calum brackets were not lining up from the silencer to the frame there not to far out I got one secure with a bit or thick tube as a washer makes it stand off a tad and might burn the plastics a bit and it wasn't very well lined up between the expansion and the silencer either il line it up better with a blow torch bit its fine for now its secure and hell ye it fits better than the old one that's been chicken shit welded im gonna only use one bracket anyway reason is to let there be a weak point for if its dropped ect minimise the damage but il cut the brackets off and re do the one il keep im in no rush to do this though
