  3. Bike running fast revs
52 Posts 7 Posters 10.9k Views
  • F Offline
    F Offline
    On mine there's a little plastic clip that holds the cable into the slide, it's bright green I think - hard to miss lol.
    Or is the cable outer coming loose from the carb top?
    • F finnerz89
      @finnerz89 that green piece is missing then I don’t remember there ever being one
        @declan any chance anyone has a pic of one so I can try make one
        ricky0115R 1 Reply Last reply
        • ricky0115R Offline
          ricky0115R Offline
          ricky0115
          Mine was doing this, turned out to be a split gasket on the reed block spacer.
            ricky0115R Offline
            ricky0115R Offline
            ricky0115
            @declan you will never make one unless you have a 3D printer, the piece never moves use a small calbe tie it should do the job
            • ricky0115R ricky0115
              @ricky0115 how would I position the tie bud?
                ricky0115R Offline
                ricky0115R Offline
                ricky0115
                @declan https://www.fowlersparts.co.uk/parts/view/3ME-1490J-00
                That’s really what you need to do it properly they don’t sell it separately.
                I was joking about the cable tie!
                  @ricky0115 your jokes are terrible lol
                    ricky0115R Offline
                    ricky0115R Offline
                    ricky0115
                    @declan your not the only person to say that 😂
                      @ricky0115 just took the part out it already has a notch built in that stops the cable from sliding out so I’m a little confused as to how it’s actually coming loose I’m gonna try a stiffer spring
                        scrimsmustang
                        @declan
                        Put 2 springs on
                        • S scrimsmustang
                          @declan
                          Put 2 springs on
                          @scrimsmustang it seems to be sorted now put a stiffer spring in
