Time to change wheels and ...
@calum yes. those are original Mikuni jets. But what size is the ralenti jet ? 25 or 15 or what ?
( https://www.japanbaiku.com/image/cache/data/chicles_tornillos/kys-00b-500x500.jpg ) thx!
Hello, I don't know if is good idea to write in this thread . Today I was checking the oil pump and I realized that the color of the oil changed: it has a suspicious color )
( I have put a transparent tube to check the oil flow)
I think it's because of oil seal or o'ring
11. O-RING
-- 13. OIL SEALWHat do you think ? Thanks in advance
@calum said in Time to change wheels and ...:
pipe
you mean that if the material the tube is made of is the right one ? the #3 in the picture.
I put the tube yesterday to check the pump, later I will put the original. I'm going to add oil to the gas tank. 100 ml of oil for 5L gas. ?
with new cilinder and piston ...I started the bike yesterday after installing the piston
pipe
