  4. Fuel hose inner diameter?
9 Posts 6 Posters 2.2k Views
  • Glynn123G Offline
    Glynn123G Offline
    Glynn123
    Anyone know the correct size of fuel hose for a DT with standard 28mm carb? I have a 6mm hose on but had to drill the ends out to fit it on the nipples so I don't think it will get enough fuel on long wide open throttle runs.
    • Glynn123G Glynn123
      Irongamer727I Offline
      @glynn123 will check if I remember in the afternoon
      • J Offline
        J Offline
        Jens Eskildsen
        6mm will flow plenty enough.
        As for your question, what size drill did you use, that should give you the answer 🙂
        • Irongamer727I Offline
          Mine is 6mm
          • tunertomT Offline
            tunertomT Offline
            tunertom
            correct stuff is 7mm, fits perfectly and still tight without stretching too much.
            i use the cotton braided proper fuel hose, its cheap on ebay and wont go brittle
            • J Offline
              J Offline
              jgr72
              Has anyone find transparent hose that will tolerate gazoline? I ordered some silicone hose from ebay, but later I realized that silicone does not tolerate gazoline... PVC hose is crap, it hardens fast and will leak easily...
              • J jgr72
                @jgr72 Stick to the braided fuel hose is my advice.
                • J Offline
                  J Offline
                  Jens Eskildsen
                  It seems like most fuellines get stiff when gas has been in them, and leaving them with no gas afterwards, like if you shut off your petcock a few hundred meters before you get home.
                  I buy mine from a scootershop for dirt cheap, and replace it once in a while (like once in a year or two)
                  I like to se whats going on, so I appreciate the clear hoses, and fuelfilters.
                  • tunertomT Offline
                    tunertomT Offline
                    tunertom
                    the proper cotton braided fuel purpose hoses last a lifetime
                    using clear ones for fuel is asking for trouble, they go brittle, crack, split, leak and are toss!
                    you dont need clear ones, there is 2 filters in the petcock and theres a filter in the carb fuel inlet barb too
