  3. TDR starting problem
30 Posts 7 Posters 7.7k Views 1 Watching
  • R
    R
    rolz82
    So same again today, was hard to start, once started it would idle fine then the idling would get faster on it's own? The gradually go back down, then it would do the same again, had it idling on the stand for 15 mins and temp was way over half way![0_1521989052033_IMG_20180325_134341.jpg](Uploading 100%)
    Glynn123G Irongamer727I 2 Replies Last reply
    • R
      R
      rolz82
      Tdr https://imgur.com/gallery/Nb5X7
      • R rolz82
        Glynn123G
        Glynn123G
        Glynn123
        @rolz82 does it have the expansion bottle in the rubber manifold between carb and reeds? Mine raises and lowers its idle on its own with that bottle, originally I thought it was an air leak and tried all sorts, once I plugged the axpansion bottle off it would idle perfect, but did lose abit of power so put it back on.
        • Glynn123G Glynn123
          Irongamer727I
          Irongamer727I
          @glynn123 lol are you trolling?
          Glynn123G 1 Reply Last reply
          • R rolz82
            Irongamer727I
            Irongamer727I
            @rolz82 clean the carb, check the reeds, check plug.
            • R
              R
              rolz82
              I've checked the plug it was oily, I'll have to clean the carb tomorrow and check the reeds
              • Irongamer727I Irongamer727
                Glynn123G
                Glynn123G
                Glynn123
                @irongamer727 don't know what you're getting at, I'm referring to the boost bottle, think they called it the YIPS system. Stores fuel and air mix for throttle blips and high loads, hence why it raises and lowers idle itself as the pressure settles in the boost bottle. Also helps with stalling etc.
                R 1 Reply Last reply
                  R
                  R
                  rolz82
                  @glynn123 think it's called the yeis bottle ( Yamaha energy induction system) something like that
                    So my DTR never started without choke. That's considered normal for these engines.
                      @calum sometimes with a fresh plug mine starts without choke although extremely rare for me
