  3. Power valve issue
Power valve issue
35 Posts 7 Posters 9.3k Views 1 Watching
  • T
    T
    thechompster
    Hi peeps. I have A 2006 dt x sm. The issue is the power valve does it's cycle when ignition is put on but when I start the engine
    it goes to the right slightly as it should I think but from there on it doesn't move at all even when revving it high. Any ideas? Havnt had the bike long. Did work well for a few weeks then occasionally but now doesn't work at all in high revs.
    • T thechompster
      @thechompster check for corroded connections or loose connections
      T 1 Reply Last reply
        T
        T
        thechompster
        @declan I did go over the connections the weekend. Some were a bit crappy so wire brushed them unless the connections are a bit dry. Didn't have any maintenance spray but will give them another clean now I have some. Would the servo make it go like that do you think?
        • T thechompster
          @thechompster itโ€™s possible the the teeth on the cogs may have snapped it worth taking a look
            T
            T
            thechompster
            @declan cogs are fine as just changed the chain so checked them both.
            • T
              T
              thechompster
              Forced the valve open while engine running and goes like stink top end. Have noticed since I done that and tuned the ignition off and on and start engine it starts to move as it should for a few revs then stops moving again. I'm taking a guess it's the solenoid?
              • T thechompster
                @thechompster It's a motor on these. So could be the brushes.
                Are you sure the valve isn't just gunked up.
                Would be worth dismantling the assembly and cleaning it thoroughly.
                T 2 Replies Last reply
                  T
                  T
                  thechompster
                  @calum it could possibly be gunked up but would it not move when you turn the ignition on?
                    T
                    T
                    thechompster
                    @calum do you have a link for how to remove power valve at all?
                    • T thechompster
                      @thechompster No, just take the two powervalve end caps off. The offside powervalve housing has a bolt to keep the two pieces together, make sure you don't lose the locating dowels as they're prone to falling out. You'll want to lubricate it with WD40.
                        T
                        T
                        thechompster
                        @calum ok thanks for the help. With give it a go.
                        • T thechompster
                          @BraDT thats how you take it apart bud
                          B 1 Reply Last reply
                            B
                            B
                            BraDT
                            @declan cheers mate ๐Ÿ‘Œ๐Ÿป
                            • T
                              T
                              thechompster
                              Took the exhaust off. A bit dirty in there but rotates easy enough. Goes through the cleaning process nice and easy so all I can do now is change the servo and hope it sorts it.
                                Odd that it'll do the cleaning cycle fine but not run right.
                                I'd be more inclined to say faulty CDI more than anything. I guess these bikes are just starting to show their age.
                                  T
                                  T
                                  thechompster
                                  @calum yeah I guess they are.apart from that it runs lovely. Will change the servo. If that doesn't do it just the cdi left I guess.
                                    Jens Eskildsen
                                    A friend had a faulty servo, sometime during a ride where the PV was open, it would leave it open. Other times just seem erratic. I believe the gears in the servo was toast.
                                    • J Jens Eskildsen
                                      T
                                      T
                                      thechompster
                                      @jens-eskildsen ok thanks mate. Very helpfull
                                      Will try another servo then and see what happens.
                                      M 1 Reply Last reply
                                      • T thechompster
                                        M
                                        M
                                        Mitch_350z
                                        @thechompster just out of interest, what spark plug are you running??
                                        • M Mitch_350z
                                          T
                                          T
                                          thechompster
                                          @mitch_350z iridium spark plug
