  3. Suspension
  4. Does DtX and DtR have the same rear shock
8 Posts 3 Posters 1.4k Views
  • B Offline
    B Offline
    Bananper
    Does the dtx shock fit straight on the dtre? Is it the same length etc?
    • B Bananper
      Irongamer727I Offline
      @bananper I changed my Dtx shock for a Dtre (I think). It was notably larger but bolted right in.
      • F Offline
        F Offline
        DTX and DTRE are the same. Check the part numbers on fowler's.
        DTR shocks will fit but they are different in every dimension
        • B Offline
          B Offline
          Bananper
          @finnerz89 @Irongamer727 so dtx and re are the same length? But R is longer?
          F 1 Reply Last reply
          • B Bananper
            F Offline
            F Offline
            @bananper yeah slightly. The damper is also different and the spring has bigger coils and is wider if that makes sense.
            B 1 Reply Last reply
            • F finnerz89
              B Offline
              B Offline
              Bananper
              @finnerz89 but dtx and re? are identical? I thought maybe X were abit stiffer?
              • B Bananper
                F Offline
                F Offline
                @bananper exact same part number
                • Irongamer727I Offline
                  In terms of stiffness I can't say I felt much difference, it feels slightly higher with the R damper.
