  3. Other
  4. the yzf project
the yzf project
29 Posts 6 Posters 16.3k Views 1 Watching
  • mad73M
    mad73M
    mad73
    bit more done this weekend got the sub frame cut down and welded up so its all hidden not the best welding buts its strong enough aint got to carry an weight
    http://i286.photobucket.com/albums/ll115/mad73_2008/pi_zpsx6yjkrxk.jpg
    http://i286.photobucket.com/albums/ll115/mad73_2008/fix_zpsuf4hx2fs.jpg
    test fit before painting
    http://i286.photobucket.com/albums/ll115/mad73_2008/fitted_zpskkthcugz.jpg
    http://i286.photobucket.com/albums/ll115/mad73_2008/trial_zpskpy6y1hh.jpg
    quick coat of satin black
    http://i286.photobucket.com/albums/ll115/mad73_2008/done_zpsz3kec0nz.jpg
    found petrol leaking from my tank so that's another thing to fix the list is getting bigger
    http://i286.photobucket.com/albums/ll115/mad73_2008/hole_zpsi8vog7mp.jpg
    had a few goodies delivered yesterday heavy duty springs and clutch plates and short levers
    http://i286.photobucket.com/albums/ll115/mad73_2008/new_zps1snkokpa.jpg
    http://i286.photobucket.com/albums/ll115/mad73_2008/levers_zps1gibbjbq.jpg
    • mad73M
      mad73M
      mad73
      ok been quite a while since last update , got quite a lot done in the 4 month its nearly finished wont put pics up yet of how I sprayed it will leave till its back together ,
      clutch done , forks rebuilt carbs on and running but not right , wont run unless on choke should be just carbs need balancing , was surprised how easy it started as it has sat for nearly 5 years
      all sprayed except clear coat , having trouble setting up digital dash will put another post up on that for help if any one can help with them ,
      wiring repaired where needed
      http://i286.photobucket.com/albums/ll115/mad73_2008/fit_zpscggs0ou6.jpg
      test fitted the body work
      http://i286.photobucket.com/albums/ll115/mad73_2008/test_zpsoupp6wzh.jpg
      as you can see its not sitting right but soon sorted that
      http://i286.photobucket.com/albums/ll115/mad73_2008/ppoiuygvcds_zpsbbqfkc7a.jpg
      http://i286.photobucket.com/albums/ll115/mad73_2008/ppoiuuy_zpsbo3c1wid.jpg
      filled all the holes in the side panels as they were cut out for crash bungs on the r1 they came off and didn't line up with my frame all so filled the indicator holes as mine are built into the mirrors
      http://i286.photobucket.com/albums/ll115/mad73_2008/kjkihygt_zpskuvpxa8a.jpg
      http://i286.photobucket.com/albums/ll115/mad73_2008/kjujhyfg_zpsqo7ylmul.jpg
      tank had a few little dents so filled all them
      http://i286.photobucket.com/albums/ll115/mad73_2008/lined_zpsdvmjtde9.jpg
      all primed and started to mask up the lines I wanted
      I will say it hasn't come out as well as I hoped but still good enough for a diy job
      more pics to come soon
        Hey its looking good bud. You certainly have been keeping busy!
        You got an eta fow when it will be done.
        mad73M 1 Reply Last reply
          mad73M
          mad73M
          mad73
          @Calum Well was gona use it this summer in just primer but I thought might as well finish it hoping it will be back together by end of the month leaving just odds and end to finish might get to get out on it a couple of times this year will have to see how it goes . This is just eating money the £800 that I had to sort it has gone no where I'm nearly double that and still got at least another £350 to put in to it
            Yeah but cmon, built nor bought right
            • mad73M mad73
              @mad73 said in the yzf project:
              The joys of restoring and customizing your mean machine! All will be forgotten when you're blasting around the twisty's with a massive grin on yer boat race!!! 😉
              • mad73M
                mad73M
                mad73
                that's why I have kept going with it ,, its only money lol
                • MightymanM
                  MightymanM
                  @CYBER-NINJA And then you'll suddenly remember again when it's inevitably time to sell up 😂
                  • mad73M
                    mad73M
                    mad73
                    Yeah that is the flip side how much is too much coz I will never get it back
                    So far I paid £600 for the bike I've done about £1400 getting it to where it is now + I have more to spend I would think by the time I've finished it will stand me in at about £2500 and it will prob be worth about £1600 on a good day , but I didn't do it to make money just to have something different and learn a bit on the way . The yzf750 was prob the best 750 of its time it still rocks by today's standards of 600s it more bike than I can handle
