DT200R (3ET) Rear Shocker
Bit of easy bling for your 125R. If you have a '99-'02 the YIES mount on the frame is helpful as a bracket for the 200R piggyback reservoir.
https://www.ebay.co.uk/itm/Yamaha-DT200R-DT200-R-3ET-Rear-Back-Suspension-Shock/332425266713?epid=12008077890&hash=item4d66170619:g:WWgAAOSwiBJZ8G5Y:rk:21:pf:0 -
Worth it if that shock is rebuildable otherwise get a YSS one new as it's now so old it's probably worn out by now
