WR 125X wheels
Look at the size difference in your brake rotors, look at where your brake would mount and then you do the math
Found a set of wr125x supermoto wheels from the 2009-2015 model was wondering if they would fit in the standard 2007 DT125RE forks?
@H-W01 said in WR 125X wheels:
Easier job if you have the forks to match - this is how I did the DTR SM I once had but that was with DTX forks so I cant say if the WR ones are the same diameter as the RE ones you have to enable a straight swap
