Brake callipers upgrade
Looking for callipers options for the dt125 to upgrade both front and rear callipers two pots or 4 pots would be desirable option
@mhbikesnbits There are none without changing the whole front end and manufacturing new brackets.
Yeah I though not but worth the ask any single barrels that fit
@mhbikesnbits Read through the threads in the brake section bud, many of the questions you will most likely ask have already been answered there.
@Calum they straight fit or custom bracket
@NINJA yeah had a little look but like to ask the question to fresh faces
@mhbikesnbits LOL nothing is a straight fit, as the crappy single pot brackets and even crappier disc bolt spacing's make it a nightmare. You would be better off doing a USD conversion and using those forks to get better brakes. Which would save you some major headaches and much expense in the log-run.
@mhbikesnbits No but a bracket is simple enough to make.
easy make yeah but sometimes I think they look like the bikes over engineered if you know what I mean
@mhbikesnbits Have woeful brakes then.
