  3. Dt125re 2004 servo
Dt125re 2004 servo
servo
11 Posts 3 Posters 1.3k Views 1 Watching
  • J Offline
    J Offline
    Jgb19830
    So my bike very heated and blown the top end. So I stripped it down disconnected the power valve etc and now i have fixed it all the power valve servo pulls 1 way when I turn the key and will not return like it did before anyone any ideas?
      Yes, if the engine hasn't been run, then the servo will only sweep one way. Then when the engines running, the powervalve moves. Then if you turn the engine on and off, it'll do the full cycle again.
      J 1 Reply Last reply
        J Offline
        J Offline
        Jgb19830
        @Calum I will get a video as it looks like it wants to keep pull the one way even when the valve is fully opened....
          I had this when my CDI went faulty.
          Could be that you haven't adjusted it appropriately, or the cables are the wrong way around.
          Disconnect the cables from the valve then do it. Does it still do it,.
          • J Offline
            J Offline
            Jgb19830
            How do these ride with the power valve pinned open.
              J Offline
              J Offline
              Jgb19830
              @Calum I will check this tomorrow
              • J Jgb19830
                @Jgb19830 Meh? Gets old quick. Noisy but fine once past 6k
                I like to disconnect it for a grin now and then!
                  J Offline
                  J Offline
                  Jgb19830
                  @Calum https://youtu.be/WuTAP7niG1o
                  • J Jgb19830
                    @Jgb19830 Okay, yeah how interested. CDI could be faulty.
                    I'm not sure how they work under the hood.
                      J Offline
                      J Offline
                      Jgb19830
                      @Calum disconnected the power for 30 seconds then reconnected... Think that's sorted it https://youtu.be/HNQbJ4AxNEU
                      • C Offline
                        C Offline
                        Ckline
                        so @Jgb19830 did you fixed it,just by that? i have the same problem.
