  4. Tzr cylinder on dt
Tzr cylinder on dt
cylinder tzr dt
4 Posts 3 Posters 864 Views 1 Watching
  • O
    O
    Oisin
    Re: Cylinder/exhaust problems
    Would a tzr cylinder work. 4FU00 is the marking on the tzr cylinders. 3MB00 is the marking on the DT's
      Gotta be careful.
      TZR's did not typically come with the 4FU barrel. They ran a different engine altogether.
      But the European Belgardas ran the 4FU barrel with the Italian models running a altered 3MB000P Barrel or the SP barrel.
      But yes, the 4FU is the same bore and stroke as the 3MB so are interchangeable. But you need the powervalve for the 4FU for it to work.
      O 1 Reply Last reply
      • DartyD
        DartyD
        4FU's are beast, Nicasil plated to.
        Slightly bigger crankcase transfers
          Gotta be careful.
          O
          O
          Oisin
          @Calum Ok thanks very much
