  3. TDR
  4. TDR 125 19XX
TDR 125 19XX
27 Posts 5 Posters 19.9k Views
  • MightymanM Mightyman
    @Calum Would I then still need a stock DT inlet for a tmx 32? Or is there a chance my current BIG inlet would be alright?
    T Offline
    T Offline
    tdrpaul
    @MIGHTYMAN the manifold in the pic is the standard manifold for the dellorto carb which has the oil pipe connection on the carb.
    Automotive addiction is real HONEST😬.
      @MIGHTYMAN Stock carb is 28mm TMX 32 is 32MM. So it should fit,.
      • MightymanM Offline
        MightymanM Offline
        #23
        Now it's (hopefully) going to be warming up outside a bit, I thought I would get back into this project again. Last night took a look at the crankshaft to find some of the bits of piston had been lodged inside the gaps in the conrod..
        https://youtu.be/oJv-wv8eEYQ
        Also started the clean up job on the engine cases.
        A bag full of steel wire rotary bits
        Starting it off
        https://youtu.be/9bUSrAkcnSs
        15 mins = 1 down!
          Looks like that crank is going to want a rebuild.
          I don't know how easy it is to get ahold of a new crank pin for these engines. If that crank pin is scored then you may find yourself needing to buy a new crank.
            MightymanM Offline
            The crank pink should have been sheilded by the bearing I would have thought? I wasn't going to rebuild the bottom end as it all turned over very smoothly but luckily I decided to pull it all apart in the end!
              What bearing lol. It's a roll cage bearing so it's completely exposed.
              If the big end bearing has got bits of piston in it then consider it thrashed.
              For the cost of 40 quid. I would rebuild the crank. Otherwise it will fail and cost you an engine.
                MightymanM Offline
                Don't worry it was going to all be rebuilt the second I opened the cases!
