  3. TDR
  4. TDR 125 19XX
TDR 125 19XX
27 Posts 5 Posters 20.2k Views
    @tdrpaul The stock carb is better than those PHBH Carbs. They are a 28mm round slide carb. Flat slide is far superior.
    T
    T
    tdrpaul
    @Calum hi Calum I agree the flat slide is a lot better carb but the dellorto phbh 28 is the standard carb for the early Italian made tdr 125.
    I have a low mileage one owner 1989 tdr and I want to keep it totally original but finding original parts isn't easy.
    Paul
    Automotive addiction is real HONEST😬.
    • MightymanM Mightyman
      I'm definitely considering just getting a stock DT carb and inlet as a Dell Orto is proving too hard / pricey to source.
      @MIGHTYMAN or grab a mikuni tmx 32. They are common enough.
      MightymanM 1 Reply Last reply
        @Calum Would I then still need a stock DT inlet for a tmx 32? Or is there a chance my current BIG inlet would be alright?
        T CalumC 2 Replies Last reply
          T
          T
          tdrpaul
          @MIGHTYMAN the manifold in the pic is the standard manifold for the dellorto carb which has the oil pipe connection on the carb.
            @MIGHTYMAN Stock carb is 28mm TMX 32 is 32MM. So it should fit,.
            • MightymanM
              #23
              Now it's (hopefully) going to be warming up outside a bit, I thought I would get back into this project again. Last night took a look at the crankshaft to find some of the bits of piston had been lodged inside the gaps in the conrod..
              https://youtu.be/oJv-wv8eEYQ
              Also started the clean up job on the engine cases.
              A bag full of steel wire rotary bits
              Starting it off
              https://youtu.be/9bUSrAkcnSs
              15 mins = 1 down!
                Looks like that crank is going to want a rebuild.
                I don't know how easy it is to get ahold of a new crank pin for these engines. If that crank pin is scored then you may find yourself needing to buy a new crank.
                • MightymanM
                  The crank pink should have been sheilded by the bearing I would have thought? I wasn't going to rebuild the bottom end as it all turned over very smoothly but luckily I decided to pull it all apart in the end!
                    What bearing lol. It's a roll cage bearing so it's completely exposed.
                    If the big end bearing has got bits of piston in it then consider it thrashed.
                    For the cost of 40 quid. I would rebuild the crank. Otherwise it will fail and cost you an engine.
                    • MightymanM
                      Don't worry it was going to all be rebuilt the second I opened the cases!
