  3. TDR
  4. TDR 125 19XX
TDR 125 19XX
27 Posts 5 Posters 20.2k Views
  • mad73M
    mad73M
    mad73
    will be a nice project
    • MightymanM
      Took the bike apart a little bit more to store it until I can make space for it.
      I'll be working on the engine first and will hopefully take a look inside this week.
      In the mean time I just need to order a rear tyre for my new rear wheel, a power valve, a carb, and a clutch case. Still unsure of what carb to buy though. My carb boot / rubber inlet measures 35mm and says 3BN on it. Is that indicating that I must buy the smaller sized carb?
      • MightymanM
        Took the cylinder off today. Found a piston with a smashed skirt!
        Cylinder walls don't look scored, but it could do with a rebore.
        The rings and small end bearing look in VERY good condition so I'm thinking at this point the previous owner may have put in a cheap eBay piston that perhaps wasn't the right size and caused piston slap?
        No up and down play on the conrod either so I'm sure that'll be good to use again without needing work done to it but I'll have to split the cases anyway just to grab any bits of piston lurking down there as I can still hear a small scratching sound when turning the engine.
        An overtightened kick start nut stopped me from progressing but I'll get that sorted tomorrow.
        Does this look like an aftermarket inlet as it doesn't have the hole for the oil pipe on top?
        • MightymanM
          Managed to get the kick starter lever nut off after I got the grinder out.
          Took the clutch cover off to find a bad sight.
          Although on the plus side, the clutch plates, springs and spring retaining bolts look brand new!
          Couldn't quite work out what the broken bits were, then these black rubber bits starting appearing from no where!
          Figured out where all the bits came from once I took the clutch off...
          That was what the scratching sound was. Couldn't work out how something like that could have happened, the only thing missing was the washer that goes on the end of the rev gear but that wouldn't have cause this amount of damage. Then I noticed this.
          I removed the gear to find that the circlip behind it had been pushed a little bit too far back. This could have caused the kick start idling gear to wiggle just enough that it hit the back of the clutch basket. Not 100% sure but seems feasible.
          Also there is a hole here, but I'm not sure if it is supposed to be there.
          All organised for another day.
          • T
            T
            tdrpaul
            Re: TDR 125 19XX
            Hi there I was going to buy this but the guy took it off eBay.
            I have the same bike that I'm tidying at the moment.
            The standard carb is a dellorto phbh 28.
            My one was imported in 2002 and registered to the guy I bought it from, the bike has been off the road in the owners shed since 2002 so the piston was seized in the bore and the carb was full of the usual green residue, nothing a new piston and a wash in my sonic bath didn't cure.
            It is a bit different to the dt like shorter rear shock, radiator ect and not being restricted is alsayw a plus.
            Good luck
            Paul
            Automotive addiction is real HONEST😬.
            • MightymanM
              Hi Paul, I did get lucky with the ad I must admit. The chap had it up for £245 on an auction and no one placed a bid! I missed it at the last minute and so messaged him offering £200 to collect and to my surprise he said yes! That's interesting that you have a 28 carb as the inlet on my engine measures around 35mm. Maybe I need to purchase another inlet if mine isn't stock.
              T 1 Reply Last reply
              • MightymanM Mightyman
                T
                T
                tdrpaul
                @MIGHTYMAN my inlet was damaged so I thought that's ok I'll fit a dt one, the dt manifold was to small for the dellorto carb so I enlarged derestricted and flowed it with the help of my trusty pen knife and a Dremel with a flap wheel on it.
                • MightymanM
                  I'm definitely considering just getting a stock DT carb and inlet as a Dell Orto is proving too hard / pricey to source.
                  T CalumC 2 Replies Last reply
                    T
                    T
                    tdrpaul
                    @MIGHTYMAN I found a dellorto phbh 28 for about £60 new, they use them a lot on vespas. I was thinking about using one on my 180 gilera runner fxr but I'm trying to keep it standard.
                    https://www.wasp-performance.co.uk/onlineshop/prod_1875543-Carburettor-PHBH-28-BS-with-Manual-Flip-Choke-Lever.html
                    I think I still have the standard jet sizes written down if you need them.
                    • T tdrpaul
                      @tdrpaul The stock carb is better than those PHBH Carbs. They are a 28mm round slide carb. Flat slide is far superior.
                        T
                        T
                        tdrpaul
                        @Calum hi Calum I agree the flat slide is a lot better carb but the dellorto phbh 28 is the standard carb for the early Italian made tdr 125.
                        I have a low mileage one owner 1989 tdr and I want to keep it totally original but finding original parts isn't easy.
                        Paul
                          @MIGHTYMAN or grab a mikuni tmx 32. They are common enough.
                          MightymanM 1 Reply Last reply
                            @Calum Would I then still need a stock DT inlet for a tmx 32? Or is there a chance my current BIG inlet would be alright?
                              T
                              T
                              tdrpaul
                              @MIGHTYMAN the manifold in the pic is the standard manifold for the dellorto carb which has the oil pipe connection on the carb.
                                @MIGHTYMAN Stock carb is 28mm TMX 32 is 32MM. So it should fit,.
                                • MightymanM
                                  #23
                                  Now it's (hopefully) going to be warming up outside a bit, I thought I would get back into this project again. Last night took a look at the crankshaft to find some of the bits of piston had been lodged inside the gaps in the conrod..
                                  https://youtu.be/oJv-wv8eEYQ
                                  Also started the clean up job on the engine cases.
                                  A bag full of steel wire rotary bits
                                  Starting it off
                                  https://youtu.be/9bUSrAkcnSs
                                  15 mins = 1 down!
                                    Looks like that crank is going to want a rebuild.
                                    I don't know how easy it is to get ahold of a new crank pin for these engines. If that crank pin is scored then you may find yourself needing to buy a new crank.
                                    • MightymanM
                                      The crank pink should have been sheilded by the bearing I would have thought? I wasn't going to rebuild the bottom end as it all turned over very smoothly but luckily I decided to pull it all apart in the end!
                                        What bearing lol. It's a roll cage bearing so it's completely exposed.
                                        If the big end bearing has got bits of piston in it then consider it thrashed.
                                        For the cost of 40 quid. I would rebuild the crank. Otherwise it will fail and cost you an engine.
                                        • MightymanM
                                          Don't worry it was going to all be rebuilt the second I opened the cases!
