  4. Dies out when I give gas
10 Posts 3 Posters 1.3k Views
  • Haako SmithH
    Haako SmithH
    Haako Smith
    My bike recently died out when I gave full throttle. I have cleaned the carb, but it still doesn’t help. Any ideas what it could be?
    • Haako SmithH Haako Smith
      @Haako-Smith virtually anything browse some threads with the search function and do some tests via the Haynes manual
      • Haako SmithH
        Haako SmithH
        Haako Smith
        When I let go off the gas it sometimes revs up really high. False air maybe?
        • Haako SmithH
          Haako SmithH
          Haako Smith
          I tried to spray some brake clean around the intake, but it didn’t make a difference
            @Haako-Smith clean carb likely a blocked jet
            Haako SmithH 1 Reply Last reply
              Haako SmithH
              Haako SmithH
              Haako Smith
              @declan
              Already cleaned it, everything is fine
                @declan
                @Haako-Smith maybe a leaky left crank seal or more simple stuff like bad petrol blocked petcock split fuel hose incorrect float height
                • Haako SmithH
                  Haako SmithH
                  Haako Smith
                  Hmm, could be the crankcase seal.
                  But it is on and off. Sometimes it bogs down, and sometimes it doesn’t. I took it for a little ride now, and now it was fine.
                  • S
                    Water in petrol? Drain the carb bowl?
                      Haako SmithH
                      Haako SmithH
                      Haako Smith
                      @SpookDog
                      Have drained the carb multiple times,
                      No water and stuff
