  3. Exhaust
  4. Exhaust help needed!
14 Posts 3 Posters 6.1k Views
  • BurridgeB Offline
    BurridgeB Offline
    Burridge
    So I should be getting my DT tomorrow and I'm looking into exhausts. Only problem is I'm not too keen on the look of any of the end cans for DTR's out there, so here's my plan:
    I get a stainless expansion chamber from Romeu, and put this Arrow can on it:
    http://i1074.photobucket.com/albums/w402/Burridge1/Mobile Uploads/image_zpsf0ikclkn.png
    But here lies my problem; I'll need the link pipe piece that runs from the chamber to the end can, but I don't want to buy something like a deep can just to chop it up for the link pipe.
    I'll most likely get my dad to weld up a flange on the end of the pipe to for the 4 bolt can on but the main problem is the pipe! Any ideas or different routes to go about it?
    • MightymanM Offline
      MightymanM Offline
      Not sure if it will be much help, but you can buy bits of stainless steel tubing off eBay.
      http://www.ebay.co.uk/itm/Stainless-Steel-Tube-Pipe-Various-Diameters-and-Lengths-/151642628838?var=450880210718&hash=item234e9ae2e6ⓂmLqgkOD-ghqgnZLxXmUgbkQ
      BurridgeB 1 Reply Last reply
      • MightymanM Mightyman
        BurridgeB Offline
        BurridgeB Offline
        Burridge
        @MIGHTYMAN Cheers mate, would be if I had a pipe vender to hand!!
        I might just end up getting the can from Romeu which he charges just an extra 40 for, it's pretty nice looking to be fair, and when I get bored of it I can modify it for the arrow.
          MightymanM Offline
          Yeah I agree about Romeu's end cans. They look very nice. I ended up buying a set of twin end cans for my DTX from him a while back. Very impracticable but they looked good!
            BurridgeB Offline
            BurridgeB Offline
            Burridge
            @MIGHTYMAN Did you get the short ones or normal length? Which look best as I'm unsure which is which in his pictures?!
              MightymanM Offline
              I prefer shorter looking cans. So I got two short ones 🙂
                BurridgeB Offline
                BurridgeB Offline
                Burridge
                @MIGHTYMAN fair enough man do you know the length of them??
                  MightymanM Offline
                  I'll measure them when I'm home and let you know.
                    BurridgeB Offline
                    BurridgeB Offline
                    Burridge
                    @MIGHTYMAN okay mate cheers!:D
                      That's what I have done on my romeu pipe. Went for the Jolly Moto one though cause they is bad man ting.
                      Yep had a flange made up and welded to the pipe to hold it all together. No biggie
                        MightymanM Offline
                        They are this size!
                        http://i.imgur.com/0cfP32D.jpg
                        http://i.imgur.com/7vOUdou.jpg
                          BurridgeB Offline
                          BurridgeB Offline
                          Burridge
                          @Calum What did you do about the link pipe from the chamber to the end can?? Or did you just put it straight on the end of the chamber?
                            They are this size!
                            BurridgeB Offline
                            BurridgeB Offline
                            Burridge
                            @MIGHTYMAN thanks mate!! Think I'll go for the longer one if I get it as don't want them to look lost behind the plastic 😛
                            • BurridgeB Burridge
                              @Burridge I had an adapter plate made up. Its all in my build thread pal.
